ANT24-0502EOL EOS
Tanımlama
The ANT24-0502 5dBi indoor omni-directional antenna can increase the effective wireless operation range of 802.11b and 802.11g wireless devices. Providing 5dBi peak Gain, it can be connected to a wireless access point or router to improve signal transmission and reception in the omni 360 degrees direction and provide point to multi-point wireless signal coverage.
Wireless devices with lower Gain detachable antennas can use this antenna to get signal transmission/reception. The ANT24-0502 antenna is equipped with an RP-SMA plug and can be attached to a wireless device equipped with an RP SMA receptacle. To attach the ANT24-0502 antenna, remove the default detachable antenna from the wireless access point or router, and connect the ANT24-0502 antenna to the RP-SMA receptacle of the wireless device.
Genel Özellikler
Frequency Range
2.4GHz to 2.5GHz
Peak Gain
5dBi (typical)
HPBW/Horizontal
360
Impedance
50 ohm (normal)
Admitted Power
2 watt
VSWR
2.0 : 1 (max.)
HPBW/Vertical
40
