Hızlı Arama
Ürün Özellikleri:
AirPremier N ™ Wireless 2.4 GHz (802.11b/g/n) access point, up to 300 Mbit / s
Genel Özellikler:
Fiziksel Özellikler
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.3ab
• IEEE 802.3u
• IEEE 802.3
Management
• Telnet - Secure (SSH) Telnet
• Web-browser
• HTTP - Secure HTTP (HTTPS)
• Support for SNMP
• The D-View - Private MIB
• AP Manager II
• An array of access points
Safety
• WPA ™ - Personal
• WPA2 ™ - Enterprise
• WPA2 ™ - Personal
• 64/128-bit WEP-encryption
• Disable SSID Broadcast
• Access Control MAC-based
• Detection of unregistered network access points
Support for VLAN / SSID
802.1q/Multiple SSID (up to 8)
Quality of service (QoS)
• 4 priority queues
• WMM Wireless Priority
Wireless Frequency Bands
From 2.4 GHz to 2.4835 GHz
Wireless speed
• IEEE 802.11b: 11, 5.5, 2 and 1 Mbit / s
• IEEE 802.11g: 108, 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• IEEE 802.11n (2.4 GHz): Up to 300 Mbits / s 2
The output power of the transmitter
IEEE 802.11b
• 24 dBm (± 2dB) at 1, 2, 5.5, 11 Mbit / s
IEEE 802.11g
• 24 ± 2 dBm at 6 ~ 24 Mbit / s
• 22 ± 2 dBm at 36 Mbit / s
• 21 ± 2 dBm at 48 Mbit / s
• 20 ± 2dBm at 54 Mbit / s
HT20
• 22 ± 2dBm at MCS0 ~ 1
• 21 ± 2dBm at MCS2 ~ 3
• 20 ± 2dBm at MCS4
• 19 ± 2dBm at MCS5
• 18 ± 2dBm at MCS6
• 17 ± 2dBm at MCS7
HT40
• 21 ± 2dBm at MCS0 ~ 3
• 20 ± 2dBm at MCS4
• 19 ± 2dBm at MCS5
• 18 ± 2dBm at MCS6
• 17 ± 2dBm at MCS7
Receiver Sensitivity
IEEE 802.11b
•-76dBm at 1 Mb / s
•-76dBm at 2 Mbit / s
• -76 dBm at 5.5 Mbit / s
• -76 dBm for 11 Mbit / s
IEEE 802.11g
•-82dBm at 6 Mbit / s
•-81dBm at 9 Mbits / s
•-79dBm at 12 Mbit / s
•-77dBm at 18 Mbit / s
•-74dBm at 24 Mbit / s
•-70dBm at 36 Mbit / s
•-66dBm at 48 Mbit / s
•-65dBm at 54 Mbit / s
HT20
•-82dBm at MCS0
•-79dBm at MCS1
•-77dBm at MCS2
•-74dBm at MCS3
•-70dBm at MCS4
•-66dBm at MCS5
•-65dBm at MCS6
•-64dBm at MCS7
HT40
•-82dBm at MCS0
•-79dBm at MCS1
•-77dBm at MCS2
•-74dBm at MCS3
•-70dBm at MCS4
•-66dBm at MCS5
•-65dBm at MCS6
•-64dBm at MCS7
Modes of operation
• The access point (AP)
• WDS access point
• WDS / Bridge (No AP Broadcast)
• Wireless client
• Repeater (software version 1.15 or higher)
The gain of the dipole antenna
2 GHz dBi@2.4
The maximum power of the transmitter
FCC: 25 dBm / ETSI: 17dBm (Dual Chain)
Indicators
• LAN
• 2.4 GHz
Fiziksel Özellikler
The maximum power consumption
8 W
Operating voltage
5 V / 2A
Operating temperature
From 0 to 40 ° C
Storage temperature
-20 To 65 ° C
Operating Humidity
From 10% to 90% (non-condensing)
Humidity
From 5% to 95% (non-condensing)
Certifications
• FCC Class B
• CE
• WiFi ®
Weight
238 g
Measurements
111 x 28 x 148 mm
1 This device is intended for indoor use. Installing the outside can lead to a violation of local regulations.
2 Maximum wireless signal rate derived from the specifications of 802.11g and 802.11n. Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual throughput. Wireless signal range can be affected by environmental factors.
Ürünler | Destek  | Haberler  | Hakkında |
