DAP-1513
Dual-band Wi-Fi 802.11n (2.4/5GGts) Mediamost, up to 300 Mbit / s
Nereden Alınır
Tanımlama
High-speed wireless bridge
DAP-1513 is a dual-band high-speed wireless bridge that can transmit data at speeds up to 300 Mbit / s with support for Wireless N technology and 2x2 MIMO. Mode of the device - the bridge (bridge): works the same as "wireless client", but provides simultaneous access to the network for multiple devices connected using Ethernet-cable (as opposed to the regime, "wireless client"). Ability to connect to the DAP-1513 computers, set-top boxes or game consoles to access the wireless network makes it ideal for online games, watching streaming HD-video, listen to music, share photos and files.DAP-1513 can function as a base station for connecting to a wireless network device of the standards 802.11a, 802.11b, 802.11g and 802.11n.
Dual Band for secure connections
DAP-1513 supports dual band (the ability to select the desired frequency range of 2.4 GHz or 5 GHz). 5 GHz band can be used for streaming video and online games. The 2.4 GHz is compatible with various devices: DAP-1513 can be connected to any wireless network operating in the 2.4 GHz band.
Simple and safe setting
WPA/WPA2 encryption protocols prevent unauthorized access to network traffic. Use the Wi-Fi Protected Setup (WPS) on the DAP-1513 to automatically configure and wireless security. This allows you to view web-sites and make purchases in the Internet without fear that unauthorized users can not view wireless traffic.
Port-based QoS
DAP-1513 supports port-based QoS, allowing you to set the priority of the connected devices by simply connecting them to the appropriate port. For example, you can connect the cable box to the port with the highest priority and to ensure that the transmission of video over the Internet is no delay, even when there is a file download to a computer
Genel Özellikler
Fiziksel Özellikler
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.11a
• IEEE 802.3
• IEEE 802.3u
Device Interfaces
• 802.11n/g/b/a wireless LAN
• 4-port LAN 10/100BASE-TX
Antenna Type
Built-in
Mode of the device
Only the "bridge" (bridge) *
Safety
• WPA and WPA2 (Wi-Fi Protected Access)
• 64/128-bit WEP-encryption
• Wi-Fi Protected setup (WPS) PBC / PIN
QoS
Port-based QoS
Wireless speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbit / s
• IEEE 802.11b: 11, 5.5, 2 and 1 Mbit / s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbit / s
• IEEE 802.11n 5 GHz for: from MCS MCS 0 to 15 (up to 300 Mbit / s)
• IEEE 802.11n to 2.4 GHz from MCS MCS 0 to 15 (up to 300 Mbit / s)
The output power of the transmitter
• IEEE 802.11a
+14 DBm at 6 ~ 54 Mbit / s
• IEEE 802.11b
+16 DBm at 1 ~ 11 Mbit / s
• IEEE 802.11g
• IEEE 802.11n for 2.4 GHz
HT-20
 +13 DBm at MCS0 / 8 - 7/15
HT-40
 +12 DBm at MCS0 / 8 - 7/15
 HT-20
+14 DBm at MCS0 / 8 - 7/15
HT-40
Receiver Sensitivity
• IEEE 802.11a
  -82 DBm at 6 Mbit / s
  -81 DBm at 9 Mbits / s
  -79 DBm at 12 Mbit / s
  -77 DBm at 18 Mbit / s
  -74 DBm at 24 Mbit / s
  -70 DBm at 36 Mbit / s
  -66 DBm at 48 Mbit / s
  -65 DBm at 54 Mbit / s
• IEEE 802.11b
  -87 DBm at 1 Mbit / s
  -87 DBm at 2 Mbit / s
  -85 DBm at 5.5 Mbit / s
  -82 DBm at 11 Mbit / s
• IEEE 802.11g
  HT-20
   -82 DBm at MCS0 / 8
   -79 DBm at MCS1 / 9
   -77 DBm at MCS2/10
   -74 DBm at MCS3/11
   -70 DBm at MCS4/12
   -66 DBm at MCS5/13
   -65 DBm at MCS6/14
   -64 DBm at MCS7/15
  HT-40
   -79 DBm at MCS0 / 8
   -76 DBm at MCS1 / 9
   -74 DBm at MCS2/10
   -74 DBm at MCS3/11
   -67 DBm at MCS4/12
   -63 DBm at MCS5/13
   -62 DBm at MCS6/14
   -61 DBm at MCS7/15
  HT-20
   -82 DBm at MCS0 / 8
   -79 DBm at MCS1 / 9
   -77 DBm at MCS2/10
   -74 DBm at MCS3/11
   -70 DBm at MCS4/12
   -66 DBm at MCS5/13
   -65 DBm at MCS6/14
   -64 DBm at MCS7/15
  HT-40
   -79 DBm at MCS0 / 8
   -76 DBm at MCS1 / 9
   -74 DBm at MCS2/10
   -74 DBm at MCS3/11
   -67 DBm at MCS4/12
   -63 DBm at MCS5/13
   -62 DBm at MCS6/14
   -61 DBm at MCS7/15
Indicators
• Power
• Wireless
Minimum system recommendations
A computer with:
• Windows ® 7, 1 , Windows Vista ® 1 , Windows ® XP sP2 1   or MAC OS ® X 2 (v10.4)
• Internet Explorer ® 6 or Mozilla ® Firefox 3.0
• The AC adapter
• CD-ROM drive
• Cable or DSL-modem
• Subscribe to online services
Fiziksel Özellikler
Operating temperature
0 º to 40 º C
Operating Humidity
From 10% to 95%, non-condensing
Measurements
142 x 122 x 60,5 mm
Weight
172 g
Certifications
• CE
• C-Tick
• FCC
• IC
• Wi-Fi Certified
1 The software included in the kit is not compatible with MAC OS.
2 The latest version of the software and documentation are available on http://support.dlink.com .
* Allows you to connect to wireless networks operating in the 2.4 GHz or 5 GHz (optional) works the same as "wireless client", but can provide simultaneous access to multiple network devices connected via Ethernet-cable.
All references to speed are for comparison only. Product specifications, size and shape are subject to change without notice, and actual product appearance may differ from that depicted on the packaging.
Çözümler
Sipariş Bilgisi
Görseller
DAP-1513
Front view
Front view
Back view
İndir
Destek Merkezi
