Hızlı Arama
Ürün Özellikleri:
The omni-directional antenna for indoor use 2.4 GHz, 8 dBi
Antenna D-Link ANT24-0802 - this is an omni-directional antenna with a gain of 8 dBi, designed for indoor use in the 2.4GHz ISM frequency band. This antenna provides high transmission / reception for wireless devices operating in the 2.4GHz ISM (Industrial, Scientific and Medical). It can be used with wireless devices 802.11n, 802.11g and 802.11b, such as access points and remote routers, and allows you to use a single device instead of several. The antenna can be used to replace the standard antenna wireless device to increase the range. It can be connected to a wireless device through a cable (supplied with antenna) or directly.
ANT24-0802 comes with a base that allows you to install the device in different places. An antenna installed in the base, which can be placed on a table or other flat surface, or may be fixed to the wall using screws. ANT24-0802 can also be attached to a metal surface with magnets that are in the bottom of the base.
Ürünler | Destek  | Haberler  | Hakkında |
