ANT24-0802CEOL EOS
The omni-directional antenna for indoor use, 8 dBi
Tanımlama
Antenna D-Link ANT24-0802C - is omni-directional antenna with a gain of 8 dBi, designed for indoor use. This antenna provides high transmission / reception for wireless network devices (for industrial, scientific and medical purposes). It can be used with wireless devices 802.11n, 802.11g and 802.11b, such as access points and remote routers, and allows you to use a single device instead of several. The antenna can be used to replace the standard antenna wireless device to increase the range.
