ANT70-CB1N
Antenna extension cable with connector N Plug, 1m
Nereden Alınır
Tanımlama
Extension cords antenna ANT70-CB1N and ANT70-CB1RN used outdoors to connect to external access points D-Link.ANT70-CB1N equipped with connectors N plug, and ANT70-CB1RN - Connectors RP-N plug and N plug. Cables have low data loss and can operate in two frequency bands - 2.4 GHz and 5 GHz. Both cables conform dust and moisture protection IP67, which means that they are dust and water tight and waterproof, and can be used in harsh outdoor conditions.
Genel Özellikler
Fiziksel Özellikler
Frequency range
2.4 ~ 6 GHz
VSWR
1.7:1 max. at 2.4 GHz
2.7:1 max. at 5 GHz
The insertion loss
0.8 dB max. at 2.4 GHz
2 dB max. at 5.15 ~ 5.85 GHz
Resistance
50 ohms
Type of cable
CFD-200
Cable Length
1 m
Jack
N Plug, N Plug
Antenna Structure
Collinear
The physical parameters
Temperature
-40 To 70 ° C
Humidity
95% at 55 ° C
Standard dust and moisture protection
IP67
Weight
199 g
Measurements
1030 x 20.9 x 20.9 mm
Çözümler
Sipariş Bilgisi
Görseller
ANT70-CB1N
Front view
İndir
Destek Merkezi
