Hızlı Arama
Ürün Özellikleri:
Wireless Controller c 2 ports 10/100/1000 Option * + 4-port 10/100/1000 LAN
Genel Özellikler:
Fiziksel Özellikler
Interface
• Ethernet: 2-port 10/100/1000 Option *, 4-port 10/100/1000 LAN
• USB: 2 USB 2.0 ports
• The console port: RJ-45
Performance
• maximum number of access points to the device (default / upgrade): 6/24 1
• maximum number of access points in the cluster (default / upgrade): 24/96 1
• The number of users at the same time passing on an adaptive authentication portal (wired / wireless): 124/400
• Dedicated VPN IPSec tunnels 2 : 70
• Dedicated tunnels VPN PPTP / L2TP 2 : 25
• Dedicated VPN SSL VPN tunnels 2 : 20
Management of access points
• Compatible managed AP: DWL-8600AP, DWL-6600AP, DWL-3600AP, DWL-2600AP
• Management and AP discovery: Layer-2, Layer-3
• Monitoring TD:
  - Managed AP
  - Unauthorized TD
  - TD, unauthenticated
  - Autonomous AP
• Monitor client
  - An authenticated client
  - Unauthorized client
  - The client is not authenticated
  - Client Ad-hoc
• Support for centralized security policy management / RF
Roaming
• Fast Roaming
• Roaming between controllers and access points that are connected to a single controller
• Intra-and internetwork roaming
Safety
• Wireless security
  - WEP, Dynamic WEP
  - WPA Personal / Enterprise
  - WPA2 Personal / Enterprise
• Intrusion Detection System in Wireless Network (WIDS)
  - Classification of rogue access points and the real
  - Rogue AP Mitigation
• Secure LAN
  - Access Control 802.1x port-based and Guest VLAN
• Authentication
  - Adaptive portal
  - Authentication MAC-address-
VLAN
• Group VLAN: Up to 255 entries
• 802.1q VLAN Tagging
• VLAN-based subnets
• VLAN port-based
Firewall 2
• Policies
  - Support for 100 rules for each function
  - Up to 600 firewall rules
• Dynamic mashrut: RIPv1, RIPv2
• Dynamic DNS
• NAT, PAT
• Web-content filtering
  - Static URL
  - Keywords
Network Setup 2
• backup route
• Load Balancing
Virtual Private Network (VPN)
• The types of encryption: DES, NULL
• IPSec NAT Traversal
• Detection of non-performing units
• IP Encapsulating Security Payload (ESP)
• IP Authentication Header (AH)
• VPN Tunnel Keep Alive
• Hub and Spoke
SSL Virtual Private Network (SSL VPN) 2
• Message integrity: MD5, SHA1
Management
• Web-interface: HTTP
• Command Line Interface
• SNMP: v1, v2c, v3
Fiziksel Özellikler
Nutrition
Internal power supply: DC 12 V / 2,5 A
Max. power consumption
19.3 W
Measurements
180 x 280 x 44 mm
Operating temperature
From 0 to 40 ° C.
Storage temperature
-20 To 70 ° C.
Operating Humidity
5 to 95%, non-condensing
EMI
FCC Class B, CE Class B, VCCI, C-tick, IC
Safety
cUL, LVD (EN60950-1)
1 Number of managed APs can be increased through the acquisition of a license for an update. 2 Options available after purchasing a license for implementing the functions VPN / router / firewall. * First port Option is enabled by default. The second port Option will be included after the acquisition of the license for realization of functions of VPN / router / firewall.
Ürünler | Destek  | Haberler  | Hakkında |
