DWC-1000Proje
Wireless Controller c 2 ports 10/100/1000 Option * + 4-port 10/100/1000 LAN
Nereden Alınır
Tanımlama
Description:
The DWC-1000 wireless controller provides centralized management of devices in a wireless LAN network. The device is a full-featured and economical solution for small and medium business networks due to the ability to control 6 to 24 wireless access points for the DWC-1000 hardware version A1 and from 12 to 66 access points for the DWC-1000 hardware version C1, 4 controllers in a common group (cluster). The automatic detection of access points and centralized management allows users to purchase an enterprise-class system without the cost of performing large-scale and complex configurations. With its robust and versatile security system, the DWC-1000 provides protection against potential attacks of unauthorized users and devices on the wireless network.
Reliable and optimal network operation
DWС-1000 supports the functions of self-optimization and recovery, which ensures the smooth operation of the wireless network. Due to the periodic scanning of radio frequency channels and performance analysis, the DWC-1000 automatically selects channels and adjusts power to avoid interference and ensure uninterrupted network operation. In order to make up for an insufficient coverage area as a result of the failure of the access point, the DWC-1000 automatically increases the output power of the transmitter of neighboring access points to increase their coverage area.
Advanced security features
The DWC-1000 is a multifunctional solution for securing networks. The device supports the Wireless Intrusion Detection System (WIDS) feature designed to detect unauthorized access points and clients, as well as various threats to wireless network security and unauthorized access. In addition, the device supports WEP, WPA Personal / Enterprise, WPA2 Personal / Enterprise, MAC-based authentication and the creation of an adaptive portal, a feature that allows users to block access until they are identified. This two-level authentication and authorization provides reliable protection against network attacks.
Scalability, availability and flexibility
Many companies often face the need to change the scale and structure of enterprises. To meet the ever-changing requirements, the DWC-1000 offers the latest solution: a Business Wireless Plus license that allows you to update the functionality of the device. D-Link offers two types of Business Wireless Plus license: to update the AP license and to update the VPN license.
Updating the AP license allows you to increase the number of managed access points: the DWC-1000 hardware version A1 controls 6 access points by default and 24 access points after the maximum number of licenses is added; DWC-1000 hardware version C1 - 12 access points by default and 66 access points after adding the maximum number of licenses.
After updating the VPN license, the DWC-1000 controller implements the functionality of the VPN, router and firewall. Firewall features allow administrators to control network access using classification policies. Ports Option provides fault tolerance of the communication channel and a backup channel for the Internet connection to provide access to the Internet.
VPN functions provide secure remote management of access points in branch offices. When building VPN tunnels, IPSec (IP Security), PPTP (Point-to-Point Tunneling Protocol) or L2TP (Layer 2 Tunneling Protocol) protocols are used to simplify the connection between the branch office and the main office via encrypted virtual channels. In addition, the use of Secure Sockets Layer (SSL) VPN tunnels provides mobile users with remote access to a centralized corporate database.
Simple operation
Centralized remote management functions provide automatic detection of compatible D-Link wireless access points, their addition to the list of managed access points and quick configuration with the same parameters as previous access points. With the ability to combine controllers into a cluster, administrators can configure and manage the entire group using a single controller. The monitoring of access points and connected stations in real time ensures efficient use of network resources. Hazard warnings and statistics collection greatly simplify management and allow optimizing network performance.
Genel Özellikler
Fiziksel Özellikler
Interface
• Ethernet: 2-port 10/100/1000 Option *, 4-port 10/100/1000 LAN
• USB: 2 USB 2.0 ports
• The console port: RJ-45
Performance
• maximum number of access points to the device (default / upgrade): 6/24 1
• maximum number of access points in the cluster (default / upgrade): 24/96 1
• The number of users at the same time passing on an adaptive authentication portal (wired / wireless): 124/400
• Dedicated VPN IPSec tunnels 2 : 70
• Dedicated tunnels VPN PPTP / L2TP 2 : 25
• Dedicated VPN SSL VPN tunnels 2 : 20
Management of access points
• Compatible managed AP: DWL-8600AP, DWL-6600AP, DWL-3600AP, DWL-2600AP
• Management and AP discovery: Layer-2, Layer-3
• Monitoring TD:
  - Managed AP
  - Unauthorized TD
  - TD, unauthenticated
  - Autonomous AP
• Monitor client
  - An authenticated client
  - Unauthorized client
  - The client is not authenticated
  - Client Ad-hoc
• Support for centralized security policy management / RF
Roaming
• Fast Roaming
• Roaming between controllers and access points that are connected to a single controller
• Intra-and internetwork roaming
Safety
• Wireless security
  - WEP, Dynamic WEP
  - WPA Personal / Enterprise
  - WPA2 Personal / Enterprise
• Intrusion Detection System in Wireless Network (WIDS)
  - Classification of rogue access points and the real
  - Rogue AP Mitigation
• Secure LAN
  - Access Control 802.1x port-based and Guest VLAN
• Authentication
  - Adaptive portal
  - Authentication MAC-address-
VLAN
• Group VLAN: Up to 255 entries
• 802.1q VLAN Tagging
• VLAN-based subnets
• VLAN port-based
Firewall 2
• Policies
  - Support for 100 rules for each function
  - Up to 600 firewall rules
• Dynamic mashrut: RIPv1, RIPv2
• Dynamic DNS
• NAT, PAT
• Web-content filtering
  - Static URL
  - Keywords
Network Setup 2
• backup route
• Load Balancing
Virtual Private Network (VPN)
• The types of encryption: DES, NULL
• IPSec NAT Traversal
• Detection of non-performing units
• IP Encapsulating Security Payload (ESP)
• IP Authentication Header (AH)
• VPN Tunnel Keep Alive
• Hub and Spoke
SSL Virtual Private Network (SSL VPN) 2
• Message integrity: MD5, SHA1
Management
• Web-interface: HTTP
• Command Line Interface
• SNMP: v1, v2c, v3
Fiziksel Özellikler
Nutrition
Internal power supply: DC 12 V / 2,5 A
Max. power consumption
19.3 W
Measurements
180 x 280 x 44 mm
Operating temperature
From 0 to 40 ° C.
Storage temperature
-20 To 70 ° C.
Operating Humidity
5 to 95%, non-condensing
EMI
FCC Class B, CE Class B, VCCI, C-tick, IC
Safety
cUL, LVD (EN60950-1)
1 Number of managed APs can be increased through the acquisition of a license for an update. 2 Options available after purchasing a license for implementing the functions VPN / router / firewall. * First port Option is enabled by default. The second port Option will be included after the acquisition of the license for realization of functions of VPN / router / firewall.
Çözümler
Sipariş Bilgisi
Görseller
DWC-1000/С1
Front view
View from the right
Back view
İndir
Destek Merkezi
