DWL-2600APEOL
A unified single-band 802.11n access point with PoE
Nereden Alınır
Tanımlama
A unified single-band Access Point DWL-2600AP with PoE is designed for indoor use and is used to build a network of business class. Easy to operate and maintain high-speed data access point DWL-2600AP provides easy integration into the existing network infrastructure that can be scaled up in the future in accordance with the requirements of the user.
Automatic Cluster Configuration
The automatic configuration of the cluster is the ideal solution for small businesses that want to install multiple access points (APs), which lack the resources to the tasks of network management solutions. When you install a small number of AP DWL-2600AP can be configured to perform automatic cluster. After the administrator setting one access point, the same settings are applied to the remaining access points. Thus, a cluster can be merged to the access points 8.
Unified management
If you are installing a network using standardized wireless switches can handle up to 192 access points DWL-2600AP, so the administrator can increase the range of your wireless network.
Safety
DWL-2600AP supports the latest security standards, including WPA and WPA2. In addition, DWL-2600AP supports up to 16 SSID, allowing the administrator to assign different access rights to user groups.
Automatic frequency adjustment
When installing multiple access points at a small distance from each other will result in interference. Upon detection of a neighbor access point DWL-2600AP can automatically select a channel without interference. This significantly reduces interference and allows the administrator to set the access point at a short distance from each other. If the neighbor APs operating on the same frequency, DWL-2600AP automatically reduces transmit power 2 . If, for any reason, neighboring APs no longer active on the network, DWL-2600AP increases the transmission power to increase the radius of coverage.
Quality of Service
DWL-2600AP supports WMM, so in case of network congestion, the priority will receive time-sensitive traffic. Furthermore, if multiple access points DWL-2600AP are in close proximity to each other, the access point will reject new connection requests, as all the resources are used. Instead, the connection request will be accepted neighboring access point. By using this function, no access point is not overloaded, while the other neighboring access points are in an idle state.
Genel Özellikler
Fiziksel Özellikler
Key Features
• Wireless Interface: 802.11b/g/n 2,4 GHz
• Interface LAN: 10/100 Fast Ethernet
• Antenna: Internal Antenna, MIMO 2x2
• Power supply: PoE or 12 V / 1 A
Frequency
802.11b/g/n: 2,4 GHz - 2.4835 GHz
Data rate
• 802.11n: 6,5 Mbit / s - 300 Mbit / s 1
• 802.11g: 54, 48, 36, 24, 12, 9 and 6 Mbit / s
• 802.11b: 11, 5.5, 2 and 1 Mbit / s
Web-based user
HTTP / HTTPS
The command line interface
• The console port with RJ45 connector
• Telnet / SSH
• SNMP
Safety
SSID
• 16 SSID
• 802.1Q VLAN
• Insulation Station
Wireless Security
• WPA Personal / Enterprise
• WPA2 Personal / Enterprise
Detection and Prevention
Classification of authorized and unauthorized access points
Authentication
Filtering by MAC-address-
Fiziksel Özellikler
Measurements
160 x 160 x 45 mm
Weight
240 grams
The power adapter
• From 100 to 240 VAC
• Output: 12 V DC, 1 A
Power over Ethernet
10/100 Mbit / s PoE (802.3af)
Housing
Standard class or «Plenum»
Operating temperature
From 0 to 40 ° C
Operating Humidity
from 10% to 90% (non-condensing)
Certifications
• CE
• FCC
• IC
• cUL
• LVD
• UL2043 (only for the class «Plenum»)
• C-Tick
• VCCI
• NCC
• Wi-Fi
• TELEC
1 300Mbit / s - this is the maximum speed wireless data standard specifications defined by IEEE 802.11n. Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead can reduce throughput.
2 This feature is available with a unified access point together with a unified wireless switch / controller.
Çözümler
Sipariş Bilgisi
Görseller
DWL-2600AP
Front view
Back view
İndir
Destek Merkezi
