DAP-1320EOL EOS
Wireless N300 wireless repeater to increase the coverage area
Nereden Alınır
Tanımlama
Wireless repeater DAP-1320 is a portable device that increases the range of the existing network. The device can be placed anywhere in your home. Compact that fits in the palm of DAP-1320 has a high capacity and supports wireless networking speeds of up to 300 Mbit / s.
Easy setup and use
There are several simple ways to set up a wireless repeater DAP-1320. You can use the application QRS Mobile, supported by mobile devices on the platform iOS or Android. You can configure the one-touch WPS button on the repeater DAP-1320 and the router or access point coverage which should be increased. In addition, you can just turn DAP-1320 into an electrical outlet, connect to the device over the wireless network from a computer or mobile device and follow the steps wizard.
Compact and easy to install design
The compact size allows you to install a repeater at home or in a small office, the device does not occupy much space and is ready for operation immediately after the connection. Wireless repeater is connected directly to an electrical outlet, so no need for extra cables and bulky power supplies. Thanks to a neat and compact design DAP-1320 will fit perfectly into any interior.
Genel Özellikler
Fiziksel Özellikler
Device Interfaces
• 802.11 n / g / b
• WPS Button
• The Reset button
Indicators
Status / WPS
Standards
IEEE 802.11b/g/n
Data rate
• IEEE 802.11b: 11, 5.5, 2 and 1 Mbit / s
• IEEE 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• IEEE 802.11n *:
MCS GI = 800ns GI = 400ns
  20MHz 40MHz 20MHz 40MHz
0 6.5 13.5 7.2 15
1 13 27 14.4 30
2 19.5 40.5 21.7 45
3 26 54 28.9 60
4 39 81 43.3 90
5 52 108 57.8 120
6 58.5 121.5 65.0 135
7 65 135 72.2 150
8 13 27 14.4 30
9 26 54 28.9 60
10 39 81 43.3 90
11 52 108 57.8 120
12 78 162 86.7 180
13 104 216 115.6 240
14 117 243 130.0 270
15 130 270 144.4 300
Unit: Mbit / s
The output power of the transmitter
• IEEE 802.11b:
  20 dBm at 1, 2, 5,5, 11 Mbit / s
• IEEE 802.11g:
  20 dBm at 6-36 Mbit / s
  19 dBm at 48 Mbit / s
  18 dBm at 54 Mbit / s
• IEEE 802.11n:
  HT20:
  20 dBm at MCS0-MCS4 and MCS8-MCS12
  19 dBm at MCS5 and MCS13
  18 dBm at MCS6-MCS7 and MCS14-MCS15
  HT40:
  19 dBm at MCS0-MCS5 and MCS8-MCS13
  18 dBm at MCS6 and MCS14
  17 dBm at MCS7 and MCS15
Receiver Sensitivity
• IEEE 802.11b:
  -87 DBm at 1 Mbit / s
  -87 DBm at 2 Mbit / s
  -85 DBm at 5.5 Mbit / s
  -82 DBm at 11 Mbit / s
• IEEE 802.11g:
  -82 DBm at 6 Mbit / s
  -81 DBm at 9 Mbits / s
  -79 DBm at 12 Mbit / s
  -77 DBm at 18 Mbit / s
  -74 DBm at 24 Mbit / s
  -70 DBm at 36 Mbit / s
  -66 DBm at 48 Mbit / s
  -65 DBm at 54 Mbit / s
• IEEE 802.11n:
  20 MHz
  -82 DBm at MCS-0/8
  -79 DBm for MCS-9/1
  -77 DBm at MCS-2/10
  -74 DBm at MCS-3/11
  -70 DBm at MCS-4/12
  -66 DBm at MCS-5/13
  -65 DBm at MCS-6/14
  -64 DBm at MCS-7/15
  40 MHz
  -79 DBm at MCS-0/8
  -76 DBm for MCS-9/1
  -74 DBm at MCS-2/10
  -74 DBm at MCS-3/11
  -67 DBm at MCS-4/12
  -63 DBm at MCS-5/13
  -62 DBm at MCS-6/14
  -61 DBm at MCS-7/15
Frequency range
From 2.4 GHz to 2.4835 GHz
Antennas
Two internal antennas
Plug
Varies by region
Safety
• Wi-Fi Protected Access (WPA and WPA2)
• 64/128-bit WEP-encryption
• WPS (PBC)
Advanced Features
Application Support QRS (iOS, Android)
Management
Web-based interface
Fiziksel Özellikler
Measurements
48 x 42 x 53.5 mm
Weight
69 g
Nutrition
From 110 to 240 VAC, 50/60 Hz
Temperature
• Operating: 0 ° to 40 ° C
• Storage: -20 ° to 65 ° C
Humidity
• Operating: 10% to 90% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certifications
• FCC
• IC
• CE
• UL
• EMI / EMC
• Wi-Fi
• C-Tick
The maximum data rate over the air to determine the technical requirements of the 802.11g and IEEE 802.11n. Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead transmission can reduce throughput. Environmental factors also adversely affect the strength of the wireless signal.
Çözümler
Sipariş Bilgisi
Görseller
DAP-1320
Left side view
Back view
Front view
İndir
Destek Merkezi
