Hızlı Arama
Ürün Özellikleri:
DWL-8610AP Tümleşik AC1750 Eşzamanlı Dual-Band PoE Kablosuz erişim noktası
Genel Özellikler:
Fiziksel Özellikler
Wireless Interfaces
• 2.4Ghz: 802.11b/g/n
• 5GHz: 802.11a/n/ac
Wired Interfaces
• RJ45 console port
• 2 10/100/1000Mbps LAN Ports (one port supporting 802.3at PoE)
LEDs
• Power
• LAN 1
• LAN 2
• Diagnostics
• 2.4 GHz
• 5 GHz
Antennas
• Internal omni-directional antennas
• 2.4GHz: 5 dBi
• 5GHz: 6.5 dBi
Wireless Frequency
• 2.4 GHz band: 2.4 GHz-2.4835 GHz
• 5 GHz band: 4.9 GHz-5.85 GHz
Data Transfer Rates
• 802.11ac: 433 Mbps-1300 Mbps
• 802.11n: 6.5 Mbps-450 Mbps
• 802.11g: 54, 48, 36, 24, 12, 9, and 6 Mbps
• 802.11b: 11, 5.5, 2, and 1 Mbps
Operating Channels
• ETSI standards 2.4/5 GHz
• 2.4 GHz: 13 channels • 5 GHz: 19 non-overlapping channels
Security
• WPA-Personal/Enterprise PSK and TKIP
• 802.11i WPA2-Personal/Enterprise PSK, TKIP and AES
• WEP 64/128-bit encryption
• SSID broadcast disable
• MAC address access control
• Internal RADIUS server
Network Management
• Operational modes
• Standalone
• AP Array
• Managed (with DWC-1000,
DWC-2000, DWS-4026 or DWS-3160)
• Web-based user interface (HTTP/HTTPS)
• Command line interface via
• RJ45 serial console
• Telnet/SSH
• SNMP
Features
• Power Adjustment
• Auto channel Selection
• 802.1p QoS
• WDS
• WMM (Wi-Fi Multimedia)
• Load Balancing
• Channel scan
• 802.11e Automatic Power Save
• 802.11h
 -Transmit Power Control (TPC)
 -Dynamic Frequency Selection (DFS)
• SVP (SpectraLink Voice Priority)
• Direct Sequence Spread Spectrum (DSSS)
• U-NII-2 Orthogonal Frequency Division Multiplexing (OFDM)
Access Control List (ACL)
• IPv4/IPv6 address
Security Setting
• EAP Types
• Station Isolation
-EAP-MD5
-EAP-TLS
-EAP-TTLS
-EAP-FAST
-EAP-SIM
-PEAP-GTC
-PEAP-TLS,
-PEAP-MS-CHAPv2
• MAC Filtering
AAA
• 802.1X
• RADIUS authentication
Dimensions
• 198 x 171 x 40 mm (7.8 x 6.7 x 1.6 in.)
Weight
• 862 grams
Power Adapter
• Input: 100 to 240 VAC
• Output: 12 VDC, 1 A
Power over Ethernet
• 802.3at PoE+
Max. Power Consumption
• 12.95 Watt
Temperature
• Operating: 0 to 40°C (32 to 104°F)
• Storage: -20~65°C-(4 to 149°F)
Humidity
Certifications
• CE
• FCC
• IC
• cUL
• LVD
• UL2043
• C-Tick
• VCCI
• NCC
• Wi-Fi
• TELEC
Ürünler | Destek  | Haberler  | Hakkında |
