DAP-2330
PoE Destekli Kablosuz N300 Erişim Noktası
Nereden Alınır
Tanımlama
Single-band Wireless Access Point DAP-2330 with support for PoE, designed for use in the networks of large enterprises and small and medium-sized businesses, allows network administrators to take advantage of the ability to manage and secure the dual-band wireless network.
High-speed wireless connection
DAP-2330 delivers reliable wireless connectivity at speeds up to 300 Mbit / s 1. With this feature, and support functions Wi-Fi Multimedia ™ (WMM) Quality of Service (QoS) Access Point DAP-2330 is an ideal solution for audio, video, and voice applications. Included in QoS feature enables the access point DAP-2330 will automatically prioritize network traffic in accordance with the level of interactive streaming, for example, HD-video or VoIP. QoS function can be adjusted via the Web-based DAP-2330 using the dropdown menu to select the user-defined rules priorities. In addition, DAP-2330 supports load balancing to ensure maximum performance by limiting the number of users per access point.
Multifunctionality
DAP-2330 allows network administrators to create a managed and secure wireless network with the best coverage. Access point DAP-2330 can be placed on the ceiling, wall or table, depending on requirements. Access Point DAP-2330 supports standard 802.3af Power over Ethernet, allowing you to install the device in areas where power outlets are not available.
Security
In order to protect your wireless network DAP-2330 supports both versions for WPA and WPA2 (802.11i), with an internal RADIUS-server, allowing users to create accounts on the device itself. The access point also supports filtering by MAC-addresses, Wireless LAN segmentation, Disable Broadcast SSID, the detection of unauthorized access points and wireless broadcast function on a schedule. DAP-2330 supports up to 8 VLAN on the frequency range that allows multiple SSID to segment users on the network. Also, the access point isolation mechanism wireless client that limits direct interaction such as "client-client." In addition, DAP-2330 supports Network Access Protection (NAP), the function of the Windows Server® 2008, which allows network administrators to specify multiple levels of network access based on the needs of each client.
Several modes of operation
To maximize cost recovery can be customized DAP-2330 in one of the following modes: Access Point, Wireless Distribution System (WDS) with Access Point, WDS / Bridge (No AP Broadcast), the wireless client. With WDS support, network administrators can set up multiple access points DAP-2330 and configure them to work with each other in bridge mode, while providing network access to individual clients. DAP-2330 also supports advanced features such as load balancing and redundancy for fail-safe wireless connection.
Network Management
Network administrators have several options for managing the access point DAP-2330, including a Web-based (HTTP), Secure Socket Layer (SSL, which provides a secure connection to the Web-based), Secure Shell (SSH, which provides a secure channel between the access point and remote computer), and Telnet. For advanced network management, administrators can use D-Link Central WiFiManager, with which you can configure and manage multiple access points from a single computer. In addition to a control, D-Link Central WiFiManager allow network administrators to remotely perform the inspection of the equipment, eliminating the need for personal control of any operations.
In addition, DAP-2330 supports wireless scheduler that disables functional wireless network when it is needed, thus saving energy. With support for PoE, manageability, several modes of operation and robust security features, the access point DAP-2330 is the ideal solution to create a wireless network at large enterprises and small and medium-sized businesses.
Genel Özellikler
Fiziksel Özellikler
Device Interfaces
• 802.11b / g / n 1
• 1 Gigabit LAN port with PoE
Indicators
• Power / Status
Standards
• IEEE 802.11b / g / n 1
• IEEE 802.3u / ab / af
Frequency Range
• 2.4 GHz to 2.4835 GHz
Antennas
• Two internal antennas with a gain of 3 dBi
Maximum output power
• 26 dBm
Wireless speed
• 802.11b: 1, 2, 5,5, 11 Mbit / s
• 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbit / s
• 802.11n:
MCS GI = 800ns GI = 400ns
  20 MHz 40 MHz 20MHz 40 MHz
0 6.5 13.5 7.2 15
1 13 27 14.4 30
2 19.5 40.5 21.7 45
3 26 54 28.9 60
4 39 81 43.3 90
5 52 108 57.8 120
6 58.5 121.5 65 135
7 65 135 72.2 150
8 13 27 14,444 30
9 26 54 28,889 60
10 39 81 43,333 90
11 52 108 57,778 120
12 78 162 86.667 180
13 104 216 115.556 240
14 117 243 130 170
15 130 270 144.444 300
Transmitter output power
• IEEE 802.11b:
  23 dBm at 1, 2, 5,5, 11 Mbit / s
• IEEE 802.11g:
  23 dBm at 6-24 Mbit / s
  22 dBm at 36 Mbit / s
  21 dBm at 48 Mbit / s
  20 dBm at 54 Mbit / s
• IEEE 802.11n:
2.4 GHz / HT-20 2.4 GHz / HT-40
23 dBm at MCS0 23 dBm at MCS0
23 dBm at MCS1 23 dBm at MCS1
23 dBm at MCS2 23 dBm at MCS2
23 dBm at MCS3 23 dBm at MCS3
23 dBm at MCS4 23 dBm at MCS4
22 dBm at MCS5 22 dBm at MCS5
21 dBm at MCS6 21 dBm at MCS6
20 dBm at MCS7 20 dBm at MCS7
23 dBm at MCS8 23 dBm at MCS8
23 dBm at MCS9 23 dBm at MCS9
23 dBm at MCS10 23 dBm at MCS10
23 dBm at MCS11 23 dBm at MCS11
23 dBm at MCS12 23 dBm at MCS12
22 dBm at MCS13 22 dBm at MCS13
21 dBm at MCS14 21 dBm at MCS14
20 dBm at MCS15 20 dBm at MCS15
Receiver Sensitivity
• IEEE 802.11b:
  -80 DBm at 2 Mbit / s
  -76 DBm at 11 Mbit / s
• IEEE 802.11g:
  -82 DBm at 6 Mbit / s
  -81 DBm at 9 Mbit / s
  -79 DBm at 12 Mbit / s
  -77 DBm at 18 Mbit / s
  -74 DBm at 24 Mbit / s
  -70 DBm at 36 Mbit / s
  -66 DBm at 48 Mbit / s
  -65 DBm at 54 Mbit / s
• IEEE 802.11n:
-82 DBm at MCS0 / 8 -79 DBm at MCS0 / 8
-79 DBm at MCS1 / 9 -76 DBm at MCS1 / 9
-76 DBm at MCS2 / 10 -74 DBm at MCS2 / 10
-74 DBm at MCS3 / 11 -71 DBm at MCS3 / 11
-70 DBm at MCS4 / 12 -67 DBm at MCS4 / 12
-66 DBm at MCS5 / 13 -63 DBm at MCS5 / 13
-65 DBm at MCS6 / 14 -62 DBm at MCS6 / 14
-64 DBm at MCS7 / 15 -61 DBm at MCS7 / 15
Functionality
Security
• WPA-Personal
• WPA-Enterprise
• WPA2-Personal
• WPA2-Enterprise
• 64/128-bit WEP encryption
• Prohibition of broadcasting SSID
• Access Control MAC-based
• Network Access Protection (NAP)
• Internal RADIUS-server
Network Management
• Telnet
• Secure Telnet (SSH)
• HTTP
• Secure HTTP (HTTPS)
• Traffic Management
• SNMP
• Module D-View - private MIB
• AP Array
Fiziksel Özellikler
Dimensions
170 x 170 x 28 mm
Weight
288.2 g with antennas
Operating Voltage
12 V / 1 A or 802.3af PoE
Max. Power Consumption
4.8 W
Temperature
• Operating: 0 to 40 C
• Storage: -20 to 65 ° C
Humidity
• Operating: 10% to 90% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certificates
• FCC
• IC
• CE
• UL
• Wi-Fi® Certified
1 Maximum wireless signal rate derived from the specifications of standards IEEE 802.11n. Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. On the range of your wireless network can be affected by environmental factors.
2 This device is intended for indoor use. Installation of the outdoors may result in a violation of local regulations.
Çözümler
Sipariş Bilgisi
Görseller
DAP-2330
Front view
İndir
Destek Merkezi
