DAP-2660/*EOL EOS
Wireless AC1200 Concurrent Dual Band PoE Access Point
Tanımlama
The DAP-2660 Wireless AC1200 Concurrent Dual Band PoE Access Point is designed to support small to medium business or enterprise environments by providing network administrators with secure and manageable dual-band wireless LAN options, and utilizing the cutting-edge speed of Wireless AC.
Super-fast Wireless AC Performance
The DAP-2660 delivers reliable, high-speed wireless performance using the latest 802.11ac standards with maximum wireless signal rates of up to 300 Mbps over the 2.4 GHz band, and 900 Mbps over the 5 GHz band*. This, coupled with support for the Wi-Fi Multimedia™ (WMM) Quality of Service (QoS) feature, makes it an ideal access point for audio, video, and voice applications. When enabled, QoS allows the DAP-2660 to automatically prioritize network traffic according to the level of interactive streaming, such as HD movies or VoIP. The QoS feature can be adjusted through the DAP-2660’s web GUI using a drop-down menu option to select customized priority rules. Additionally, the DAP-2660 supports load balancing to ensure maximum performance by limiting the maximum number of users per access point.
Versatile Access Point Functionality
The DAP-2660 allows network administrators to deploy a highly manageable and extremely robust simultaneous dual-band wireless network. The DAP-2660 can provide optimal wireless coverage over either the 2.4 GHz (802.11b, 802.11g, and 802.11n) or the 5 GHz (802.11a, 802.11n, and 802.11ac) band. The DAP-2660 can be ceiling mounted, wall mounted, or placed on a desktop to meet any wireless demands. For advanced installations, the DAP-2660 has integrated 802.3af Power over Ethernet (PoE) support, allowing this device to be installed in areas where power outlets are not readily available.
Security
To help maintain a secure wireless network, the DAP-2660 supports both Personal and Enterprise versions of WPA and WPA2 (802.11i), with support for RADIUS server backend and a built-in internal RADIUS server allowing users to create their accounts within the device itself. This access point also includes MAC address filtering, wireless LAN segmentation, SSID broadcast disable, rogue AP detection, and wireless broadcast scheduling to further protect your wireless network. The DAP-2660 includes support for up to eight VLANs per band for implementing multiple SSIDs to further help segment users on the network. It also includes a wireless client isolation mechanism, which limits direct client-to-client communication. Additionally, the DAP-2660 supports Network Access Protection (NAP), a feature of Windows Server® 2008, allowing network administrators to define multiple levels of network access based on individual client’s need.
Multiple Operation Modes
To maximize total return on investment, the DAP-2660 can be configured to optimize network performance based on any one of its multiple operation modes: Access Point, Wireless Distribution System (WDS) with Access Point, WDS/Bridge (No AP Broadcasting), and Wireless Client. With WDS support, network administrators can set up multiple DAP-2660s throughout a facility and configure them to bridge with one another while also providing network access to individual clients. The DAP-2660 also features advanced features such as load balancing and redundancy, for fail-safe wireless connectivity.
Network Management
Network administrators have multiple options for managing the DAP-2660, including web (HTTP), Secure Socket Layer (SSL, which provides for a secure connection to the Internet), Secure Shell (SSH, which provides for a secure channel between local and remote computers), and Telnet. For advanced network management, administrators can use the D-Link Central WiFiManager to configure and manage multiple access points from a single location. In addition, the D-Link Central WiFiManager provides network administrators with the means of conducting regular maintenance checks remotely, eliminating the need for sending out personnel to physically verify proper operation.
The DAP-2660 has a wireless scheduler feature, which turns off wireless functionality when it isn’t needed, saving power. With simultaneous dual-band functionality, PoE support, extensive manageability, versatile operation modes, and solid security enhancements, the DAP-2660 provides small to medium business and enterprise environments with a business-class solution for deploying a wireless network.
Genel Özellikler
Device Interfaces
• 802.11a/b/g/n/ac wireless*
• 1 Gigabit LAN Port (supports PoE)
LEDs
• Power
Standards
• IEEE 802.11a/b/g/n/ac*
• IEEE 802.3u/ab/af
Wireless Frequency Range
• 2.4 GHz band: 2.4 GHz to 2.4835 GHz
• 5 GHz band: 5.15 to 5.35 GHz, 5.47 to 5.85 GHz**
Antennas
• Two internal 3 dBi for 2.4 GHz
• Two internal 4 dBi for 5 GHz
Maximum Output Power***
• 26 dbm for 2.4GHz
• 26 dbm for 5GHz
Wireless Speed*
• 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbit/s
• 802.11b: 1, 2, 5.5, 11 Mbit/s
• 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbit/s
• 802.11n:
| MCS | GI=800ns | GI=400ns | ||
| 20 МГц | 40 МГц | 20МГц | 40 МГц | |
| 0 | 6,5 | 13,5 | 7,2 | 15 |
| 1 | 13 | 27 | 14,4 | 30 |
| 2 | 19,5 | 40,5 | 21,7 | 45 |
| 3 | 26 | 54 | 28,9 | 60 |
| 4 | 39 | 81 | 43,3 | 90 |
| 5 | 52 | 108 | 57,8 | 120 |
| 6 | 58,5 | 121,5 | 65 | 135 |
| 7 | 65 | 135 | 72,2 | 150 |
| 8 | 13 | 27 | 14,444 | 30 |
| 9 | 26 | 54 | 28,889 | 60 |
| 10 | 39 | 81 | 43,333 | 90 |
| 11 | 52 | 108 | 57,778 | 120 |
| 12 | 78 | 162 | 86,667 | 180 |
| 13 | 104 | 216 | 115,556 | 240 |
| 14 | 117 | 243 | 130 | 170 |
| 15 | 130 | 270 | 144,444 |
300 |
• 802.11ac: 6.5–1300 Mbit/s
The Output Power of Transmitter
• IEEE 802.11a:
23 dBm at 6 Mbit/s
23 dBm at 9 Mbit/s
23 dBm at 12 Mbit/s
23 dBm at 18 Mbit/s
23 dBm at 24 Mbit/s
22 dBm at 36 Mbit/s
21 dBm at 48 Mbit/s
20 dBm at 54 Mbit/s
• IEEE 802.11b:
23 dBm at 1, 2, 5.5, 11 Mbit/s
• IEEE 802.11g:
23 dBm at 6-24 Mbit/s
22 dBm at 36 Mbit/s
21 dBm at 48 Mbit/s
20 dBm at 54 Mbit/s
• IEEE 802.11n:
2,4 ГГц/HT-20
23 dBm при MCS0
23 dBm при MCS1
23 dBm при MCS2
23 dBm при MCS3
23 dBm при MCS4
22 dBm при MCS5
21 dBm при MCS6
20 dBm при MCS7
23 dBm при MCS8
23 dBm при MCS9
23 dBm при MCS10
23 dBm при MCS11
23 dBm при MCS12
22 dBm при MCS13
21 dBm при MCS14
20 dBm при MCS15
2,4 ГГц/HT-40
23 dBm при MCS0
23 dBm при MCS1
23 dBm при MCS2
23 dBm при MCS3
23 dBm при MCS4
22 dBm при MCS5
21 dBm при MCS6
20 dBm при MCS7
23 dBm при MCS8
23 dBm при MCS9
23 dBm при MCS10
23 dBm при MCS11
23 dBm при MCS12
22 dBm при MCS13
21 dBm при MCS14
20 dBm при MCS15
5 ГГц/HT-20
23 dBm при MCS0
23 dBm при MCS1
23 dBm при MCS2
23 dBm при MCS3
23 dBm при MCS4
22 dBm при MCS5
20 dBm при MCS6
19 dBm при MCS7
23 dBm при MCS8
23 dBm при MCS9
23 dBm при MCS10
23 dBm при MCS11
23 dBm при MCS12
22 dBm при MCS13
20 dBm при MCS14
19 dBm при MCS15
5 ГГц/HT-40
23 dBm при MCS0
23 dBm при MCS1
23 dBm при MCS2
23 dBm при MCS3
23 dBm при MCS4
22 dBm при MCS5
20 dBm при MCS6
19 dBm при MCS7
23 dBm при MCS8
23 dBm при MCS9
23 dBm при MCS10
23 dBm при MCS11
23 dBm при MCS12
22 dBm при MCS13
20 dBm при MCS14
19 dBm при MCS15
• IEEE 802.11ac:
VHT20
23 dBm при MCS0
23 dBm при MCS1
23 dBm при MCS2
23 dBm при MCS3
23 dBm при MCS4
22 dBm при MCS5
20 dBm при MCS6
19 dBm при MCS7
17 dBm при MCS8
15 dBm при MCS9
VHT40
23 dBm при MCS0
23 dBm при MCS1
23 dBm при MCS2
23 dBm при MCS3
23 dBm при MCS4
22 dBm при MCS5
20 dBm при MCS6
19 dBm при MCS7
17 dBm при MCS8
15 dBm при MCS9
VHT80
23 dBm при MCS0
23 dBm при MCS1
23 dBm при MCS2
23 dBm при MCS3
23 dBm при MCS4
22 dBm при MCS5
20 dBm при MCS6
19 dBm при MCS7
17 dBm при MCS8
15 dBm при MCS9
Receiver Sensitivity
• IEEE 802.11a:
-82 dBm at 6 Mbit/s
-81 dBm at 9 Mbit/s
-79 dBm at 12 Mbit/s
-77 dBm at 18 Mbit/s
-74 dBm at 24 Mbit/s
-70 dBm at 36 Mbit/s
-66 dBm at 48 Mbit/s
-65 dBm at 54 Mbit/s
• IEEE 802.11b:
-80 dBm at 2 Mbit/s
-76 dBm at 11 Mbit/s
• IEEE 802.11g:
-82 dBm at 6 Mbit/s
-81 dBm at 9 Mbit/s
• IEEE 802.11n:
2,4 ГГц/HT-20
-82 dBm при MCS0/8
-79 dBm при MCS1/9
-76 dBm при MCS2/10
-74 dBm при MCS3/11
-70 dBm при MCS4/12
-66 dBm при MCS5/13
-65 dBm при MCS6/14
-64 dBm при MCS7/15
2,4 ГГц/HT-40
-79 dBm при MCS0/8
-76 dBm при MCS1/9
-74 dBm при MCS2/10
-71 dBm при MCS3/11
-67 dBm при MCS4/12
-63 dBm при MCS5/13
-62 dBm при MCS6/14
-61 dBm при MCS7/15
5 ГГц/HT-20
-82 dBm при MCS0
-79 dBm при MCS1
-77 dBm при MCS2
-74 dBm при MCS3
-70 dBm при MCS4
-66 dBm при MCS5
-65 dBm при MCS6
-64 dBm при MCS7
5 ГГц/HT-40
-79 dBm при MCS0
-76 dBm при MCS1
-74 dBm при MCS2
-71 dBm при MCS3
-67 dBm при MCS4
-63 dBm при MCS5
-62 dBm при MCS6
-61 dBm при MCS7
• IEEE 802.11ac:
VHT20
-82 dBm при MCS0
-79 dBm при MCS1
-77 dBm при MCS2
-74 dBm при MCS3
-70 dBm при MCS4
-66 dBm при MCS5
-65 dBm при MCS6
-64 dBm при MCS7
-59 dBm при MCS8
-57 dBm при MCS9
VHT40
-79 dBm при MCS0
-76 dBm при MCS1
-74 dBm при MCS2
-71 dBm при MCS3
-67 dBm при MCS4
-63 dBm при MCS5
-62 dBm при MCS6
-61 dBm при MCS7
-56 dBm при MCS8
-54 dBm при MCS9
VHT80
-76 dBm при MCS0
-73 dBm при MCS1
-71 dBm при MCS2
-68 dBm при MCS3
-64 dBm при MCS4
-60 dBm при MCS5
-59 dBm при MCS6
-58 dBm при MCS7
-53 dBm при MCS8
-51 dBm при MCS9
Security
• WPA-Personal
• WPA-Enterprise
• WPA2-Personal
• WPA2-Enterprise
• WEP 64/128-bit encryption
• SSID broadcast disable
• MAC address access control
• Network Access Protection (NAP)
• Internal RADIUS server
Network Management
• Telnet
• Secure Telnet (SSH)
• HTTP
• Secure HTTP (HTTPS)
• Traffic control
• SNMP
• D-Link Central WiFiManager
• AP Array
Çözümler
Sipariş Bilgisi
