DWL-6700APProje
Dual Band Outdoor Wireless Unified Access Point
Nereden Alınır
Tanımlama
Outdoor Wireless Dual Band unified access point D-Link DWL-6700AP is designed for use in enterprise networks that require data transfer for small and medium distances.
2 bandwidth
5 GHz WDS-organization of the compounds, 2.4 GHz to create a wireless local area network
Modern wireless standard 802.11n
High-speed connections - up to 300 Mbit / s
Ability to use outdoors
Wide operating temperature range - from -30 ° C to 50 ° C
Protected housing
Plastic housing with a protection class of dust and moisture IP55
The maximum effective installation
Signal level Wi-Fi, which allows to choose the optimal location for the access point
Centralized management
Working in a controlled access point with wireless switches and controllers D-Link
Flexible access to a wireless network
The access point supports MIMO 2x2 and is equipped with two built-in directional antennas with a gain of 8 dBi for 5 GHz frequency band and two omnidirectional antennas with a gain of 3 dBi for 2.4 GHz. This solution enables stable operation of WDS-connections on medium distances in the 5 GHz band and thus arrange local access to a wireless network in the 2.4GHz band.
Centralized management of the wireless network
When working with the unified switches or controllers D-Link Access Point DWL-6700AP supports centralized management that makes it easy to configure and manage a large number of APs. After the discovery of the switch or access point controller, the administrator can specify a single configuration for all of TD immediately instead configure each AP individually. In addition to that provided centralized management of radio frequency resources and security settings, which in turn allows the administrator to pre-identify potential weaknesses and vulnerabilities in the network.
LED signal strength Wi-Fi and a remote reset button
This access point is equipped with an indicator signal Wi-Fi, which allows to monitor the signal WDS-connections for the 5 GHz frequency range. Thus, the administrator can easily determine the optimum location of the AT required to obtain the maximum signal when receiving from the AT on the opposite side, even if two access points are located at a distance of 2 km from each other. In addition to the main button reset to factory settings, located directly on the access point to the factory settings can be performed remotely using a special button on PoE-injector supplied with the AP.
Quality of Service
DWL-6700AP supports 802.1p Quality of Service (QoS) to increase throughput and productivity when transferring delay-sensitive traffic, for example, VoIP and video streaming. Since DWL-6700AP supports WMM, in the case of a high network load will primarily handle the traffic with the highest priority. In addition, the access point DWL-6700AP supports load balancing. If multiple TD-enabled load balancing are in close proximity to each other, the TD, whose resources are fully utilized, will reject new connection requests. Instead, the connection request will be accepted by the neighboring access point. Thus, by using this feature, the load on the access points will be distributed evenly.
Genel Özellikler
Fiziksel Özellikler
Hardware
Interfaces
• IEEE 802.11a / b / g / n
• Two LAN ports 10 / 100Base-TX featuring PoE (PoE supply to the LAN1 or LAN2, proprietary implementation of PoE, does not meet the standard 802.3af / at)
• Console port with RJ-45
Indicators
• Condition
• LAN1
• LAN2
• The signal strength Wi-Fi (5 GHz)
• 2.4 GHz
Buttons • Reset to the factory settings
Antenna
• 5GHz: Two built-in directional antenna with a gain of 8 dBi
• 2,4 GHz: Two built-in omni-directional antenna with a gain of 3 dBi
Scheme MIMO • 2x2
Housing • Plastic (protection class IP55)
The parameters of the wireless module
Standards • IEEE 802.11a / b / g / n
Frequency Range
• 802.11b / g / n: from 2.4 GHz to 2.4835 GHz
• 802.11a / n: from 5.15 GHz to 5.825 GHz
Wireless Security
• Up to 8 SSID, SSID to a range of 4
• 802.1Q VLAN
• WPA-Personal / Enterprise
• WPA2-Personal / Enterprise
• AES and TKIP
• Filtering by MAC-address-
Wireless speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit / s
• IEEE 802.11b: 1, 2, 5.5 and 11 Mbit / s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit / s
• IEEE 802.11n 1:
MCS GI = 800ns GI = 400ns
  20 MHz 40 MHz 20MHz 40 MHz
0 6.5 13.5 7.2 15
1 13 27 14.4 thirty
2 19.5 40.5 21.7 45
3 26 54 28.9 60
4 39 81 43.3 90
5 52 108 57.8 120
6 58.5 121.5 65 135
7 65 135 72.2 150
8 13 27 14.444 thirty
9 26 54 28.889 60
10 39 81 43.333 90
eleven 52 108 57.778 120
12 78 162 86.667 180
13 104 216 115.556 240
14 117 243 130 170
15 130 270 144.444 300
Unit: Mbit / s
Transmitter output power
The maximum transmit power will vary according to the rules of radio frequency regulation in your country.
• IEEE 802.11a:
   20 dBm at 6 ~ 18 Mbit / s
   19 dBm at 24 Mbit / s
   18 dBm at 36 Mbit / s
   17 dBm at 48 Mbit / s
   15 dBm at 54 Mbit / s
• IEEE 802.11b:
   20 dBm at 1 Mbit / s
   19 dBm at 2 Mbit / s
   17 dBm at 5.5 and 11 Mbit / s
• IEEE 802.11g:
• IEEE 802.11n:
   2.4 GHz / HT-20:
   20 dBm at MCS0-MCS3, MCS8-MCS11
   19 dBm at MCS4, MCS12
   18 dBm at MCS5, MCS13
   17 dBm at MCS6, MCS14
  16 dBm at MCS7, MCS15
   2.4 GHz / HT-40:
   19 dBm at MCS0-MCS3, MCS8-MCS11
   17 dBm at MCS4, MCS12
   16 dBm at MCS5, MCS13
   14 dBm at MCS6-MCS7, MCS14-MCS15
   5GHz / HT-20:
   11 ± 2 dBm at MCS0-MCS3, MCS8-MCS11
   10 ± 2 dBm at MCS4-MCS5, MCS12-MCS-13
   9 ± 2 dBm at MCS6-MCS7, MCS14-MCS15
   5GHz / HT-40:
Receiver Sensitivity
• IEEE 802.11a:
   -85 DBm at 6 Mbit / s
   -84 DBm at 9 and 12 Mbit / s
   -82 DBm at 18 Mbit / s
   -78 DBm at 24 Mbits / s
   -73 DBm at 36 Mbit / s
   -70 DBm at 48 Mbit / s
   -68 DBm at 54 Mbit / s
• IEEE 802.11b:
   -89 DBm at 1 and 2 Mbit / s
   -84 DBm at 5.5 and 11 Mbit / s
• IEEE 802.11g:
• IEEE 802.11n:
   2.4 GHz / HT-20:
   -82 DBm at MCS0 / 8
   -79 DBm at MCS1 / 9
   -77 DBm at MCS2 / 10
   -74 DBm at MCS3 / 11
   -70 DBm at MCS4 / 12
   -66 DBm at MCS5 / 13
   -65 DBm at MCS6 / 14
   -64 DBm at MCS7 / 15
   2.4 GHz / HT-40:
   -79 DBm at MCS0 / 8
   -76 DBm at MCS1 / 9
   -74 DBm at MCS2 / 10
   -71 DBm at MCS3 / 11
   -67 DBm at MCS4 / 12
   -63 DBm at MCS5 / 13
   -62 DBm at MCS6 / 14
   -61 DBm at MCS7 / 15
   5GHz / HT-20:
   -82 ± 2 dBm at MCS0 / 8
   -79 ± 2 dBm at MCS1 / 9
   -77 ± 2 dBm at MCS2 / 10
   -74 ± 2 dBm at MCS3 / 11
   -70 ± 2 dBm at MCS4 / 12
   -66 ± 2 dBm at MCS5 / 13
   -65 ± 2 dBm at MCS6 / 14
   -64 ± 2 dBm at MCS7 / 15
   5GHz / HT-40:
   -79 ± 2 dBm at MCS0 / 8
   -76 ± 2 dBm at MCS1 / 9
   -74 ± 2 dBm at MCS2 / 10
   -71 ± 2 dBm at MCS3 / 11
   -67 ± 2 dBm at MCS4 / 12
   -64 ± 2 dBm at MCS5 / 13
   -63 ± 2 dBm at MCS6 / 14
   -62 ± 2 dBm at MCS7 / 15
Functionality
Network Management
• Web-interface (HTTP / HTTPS)
• Command Line Interface (only available when you connect through the console port is an RJ-45)
Modes of operation
• Access point
• WDS
Supported Features
• Quality of Service (QoS)
• WMM
Standards
• IEEE 802.3i
• IEEE 802.3u
• IEEE 802.3x
Physical parameters
The weight • 495 g
Sizes • 280 x 115 x 50 mm
terms of Use
Food
• PoE (PoE supply to the LAN1 or LAN2, proprietary implementation of PoE, does not meet the standard 802.3af / at)
• Power adapter (PoE-injector), output: 24 V DC, 1 A
Max Power Consumption • 8 W (when using PoE-injector, included in the package)
ESD protection • Up to 6 kW
Temperature
• Working: -30 ° to 50 ° C
• Storage: -30 ° to 65 ° C
Humidity
• Storage: 5% to 95% non-condensing
Contents of delivery
• Wireless Access Point DWL-6700AP
• Ethernet-Cable
• A set of ground wire and screw
• Clamps for cable (2 pcs.)
• Power cable
• Warranty Card
• Installation CD
Other
Certifications
• CE
• EN 301 893 V1.7.1 (2012-06) (DFS / TPC)
• EN 300 328 V1.8.1 (2012-06)
• FCC
• IC
• cUL
• LVD
• C-Tick
• NCC
• Wi-Fi
• TELEC
1 Maximum wireless signal rate derived from the specifications of the standard IEEE 802.11n. The data rate can vary significantly from the speed of the wireless connection. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate.
Çözümler
Sipariş Bilgisi
Görseller
DWL-6700AP
View from the right
View from the right
Back view
Front view
İndir
Destek Merkezi
