DAP-1325
N300 Wi-Fi Range Extender
Nereden Alınır
Tanımlama
Wireless Interface
The wireless extender DAP-1325 is a portable device designed to increase the operational range of your wireless network. The extender supports operation with wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 300Mbps).
The device supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, different operation modes (repeater, client, access point), WMM.
WPS support allows connecting to the existing wireless network of a router or another access point and also allows adding wireless clients to the network of DAP-1325 by pressing the WPS button on the device.
LAN Port
The wireless extender is equipped with one Fast Ethernet LAN port, which can be used to connect a wired client to the extender or to connect DAP-1325 to a wired router.
Signal Strength LED
The LED clearly shows the signal level of the wireless network to which DAP-1325 is connected. Due to this, you can easily find the best location for the extender.
Easy Configuration and Update
You can configure the settings of the DAP-1325 device via the user-friendly web-based interface (the interface is available in two languages – in Russian and in English).
The configuration wizard allows you to quickly switch the extender to the access point, repeater, or client mode and configure all needed settings for the selected mode in several simple steps.
You can simply update the firmware: when the Internet access is provided, the extender itself finds approved firmware on D-Link update server and notifies when ready to install it.
Repeater Mode
You can connect DAP-1325 in the repeater mode to a wireless router for extending the range of the existing wireless network.
Client Mode
In the client mode, you can let a wired PC connected to DAP-1325 access the network of a wireless router.
Access Point Mode
You can connect DAP-1325 in the access point mode to a wired router for adding a wireless network to the existing local network.
Genel Özellikler
Hardware
Processor • MT7628NN (580MHz)
RAM • 64MB, DDR2 SDRAM
Flash • 8MB, SPI
Interfaces
• 10/100BASE-TX LAN port
LEDs
• POWER/WPS
• Wi-Fi Signal Strength
Buttons
• WPS button to set up wireless connection
• RESET button to restore factory default settings
Antenna
• Two external non-detachable antennas (2 dBi)
MIMO
• 2 x 2
Power connector
• CEE 7/16 plug for AC power supply
Software
Network functions
• DHCP server
• Automatic obtainment of LAN IP address
• Advanced configuration of built-in DHCP server
• DNS relay
Management
• Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
• Bilingual web-based interface for configuration and management (Russian/English)
• Support of logging to remote host
• Ping utility
• Traceroute utility
Wireless Module Parameters
Standards
• IEEE 802.11b/g/n
Frequency range
• 2400 ~ 2483.5MHz
Wireless connection security
• WEP
• МАС filter
• WPS (PBC/PIN)
Advanced functions
• Support of client mode
• WMM (Wi-Fi QoS)
• Information on connected Wi-Fi clients
• Advanced settings
• Support of MBSSID
Wireless connection rate
• IEEE 802.11b: 1, 2, 5.5, and 11Mbps
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11n:  from 6.5 to 300Mbps (from MCS0 to MCS15)
Transmitter output power
• 802.11n (typical at room temperature 25 °C)
15dBm (+/-1.5 dB)
Receiver sensitivity
• 802.11n (typical at PER = 10% (1000-byte PDUs) at room temperature 25 °C)
HT20
-82dBm at MCS0/8
-79dBm at MCS1/9
-77dBm at MCS2/10
-74dBm at MCS3/11
-70dBm at MCS4/12
-66dBm at MCS5/13
-65dBm at MCS6/14
-64dBm at MCS7/15
HT40
-79dBm at MCS0/8
-76dBm at MCS1/9
-74dBm at MCS2/10
-71dBm at MCS3/11
-67dBm at MCS4/12
-63dBm at MCS5/13
-62dBm at MCS6/14
-61dBm at MCS7/15
Physical Parameters
Dimensions (L x W x H)
• 51 x 49 x 98 mm (2 x 1.91 x 3.85 in)
Weight
• 97 g (0.21 lb)
Operating Environment
Power
• Input: 110 to 240 V AC, 50/60 Hz
Temperature
• Operating: from 0 to 40 °C
• Storage: from -20 to 70 °C
Humidity
• Operating: from 10% to 90% (non-condensing)
• Storage: from 5% to 90% (non-condensing)
Delivery Package
• Extender DAP-1325
Fiziksel Özellikler
Çözümler
Sipariş Bilgisi
DAP-1325  N300 Wi-Fi Range Extender
Görseller
DAP-1325/A1
Front view
View from the right
Left side view
Back view
Вид снизу
İndir
Destek Merkezi
