DAP-1360/BEOL EOS
Wireless N 300 Access Point & Router
Nereden Alınır
Tanımlama
Wireless Interface
Using DAP-1360, you are able to quickly create a wireless network and let your relatives or employees connect to it virtually anywhere (within the operational range of your wireless network). The access point can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 300Mbps).
The device supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, different operation modes (access point, router, client), WPS, WDS, WMM.
Security
In the router mode, the DAP-1360 device includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Access Point Mode
You are able to use DAP-1360 switched to the access point mode to create a wireless network or to connect to a wired router.
Router Mode
You are able to connect DAP-1360 switched to the router mode to a cable or DSL modem or to a private Ethernet line and use a high-speed Internet connection to successfully fulfill a wide range of professional tasks.
“Client” Function
The “client” function in the access point mode allows using DAP-1360 as a wireless client and a wireless repeater, in the router mode as a WISP repeater.
Configuration and Management
You can configure and manage the settings of the DAP-1360 device via the user-friendly web-based interface (the interface is available in several languages).
Genel Özellikler
Hardware
• WAN Interface: 1 10/100BASE-TX Ethernet port for cable or DSL modem or private Ethernet line.
• LAN Interface: 1 10/100BASE-TX Ethernet port.
•  WLAN Interface:
  - IEEE 802.11n (up to 300Mbps)
  - IEEE 802.11b/g.
Software
Operation Modes:
• Access point mode
• Router mode.
Network Functions:
• WAN connection types:
  - PPPoE
  - Static IP
  - Dynamic IP
  - PPTP/L2TP + Static IP
  - PPTP/L2TP + Dynamic IP
• DHCP server and client
• DNS relay
• VPN pass-through (PPTP/L2TP)
• Dynamic DNS
• Static IP routing
• Remote management
• Network statistics for each interface
• IGMP Proxy
• RIP
• UPnP
• WAN ping respond.
Wireless Connection:
• WLAN splitting (up to 4 SSIDs)
• Supported security settings:
  - WEP
  - WPA/WPA2 Personal
• MAC filter
• Managing connected stations
• PIN and PBC methods of WPS
• WMM (Wi-Fi QoS)
• Advanced settings
• WDS
• “Client” function (access point mode):
  - Wireless network client
  - Wireless network repeater
• “Client” function (router mode):
  - WISP repeater.
Firewall Functions:
• IP filters
• URL filter
• MAC filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers.
Configuration and Management:
• Multilingual web-based interface for configuration and management
• Access via TELNET
• Support of remote logging
• Automatic synchronization of system time with NTP server (router mode)
• Ping function
• Traceroute utility (router mode).
Physical and Environmental
LEDs:
• Power
• WLAN
• WPS
• LAN
• Internet.
Power:
• External power adapter DC 12V
• Reset to Factory Defaults button
• WPS button.
Operating Temperature:
• from 0 to 40 0C (from 32 to 104 0F).
Storage Temperature:
• from -20 to 65 0С (from -4 to 149 0F).
Operating Humidity:
• from 10% to 90% non-condensing.
Storage Humidity:
• from 5% to 95% non-condensing.
Fiziksel Özellikler
Çözümler
Sipariş Bilgisi
DAP-1360/B Wireless N 300 Access Point & Router
Görseller
DAP-1360/B
Front view
Back view
İndir
Destek Merkezi
