Ürün Özellikleri:
Dahili 4 dBi Çok Yönlü Tavan tipi Anten EOL |
Tanımlama:
The D-Link ANT24-0401 connects to the DWL-900AP+, DI-614+, DI-714P+, DWL-900AP, DI-714 and DI-713P. The D-Link ANT24-0401 antenna provides extended coverage for an existing 802.11b wireless local area network (WLAN). Using a reverse SMA connect- or, the D-Link ANT24-0401 is easily connected to the D-Link DWL-900AP+ wireless access point, DI-614+ wireless router, DI-714P+ wireless router, DWL-900AP wireless access point, DI-714 wireless router and the DI-713P wireless router Rev C1 or later wireless broadband router. The D-Link ANT24-0401 requires an access point or wireless broadband gateway with a reverse SMA connector. The D-Link ANT24-0401 is easily connected to the DWL-900AP+ wireless access point, DI-614+ wireless router, DI-714P+ wireless router, DWL-900AP wireless access point, DI-714 wireless router and the DI-713P wireless router Rev C1 or later wireless broadband router. Note: This product does not currently work with the enterprise DWL-1750 wireless router DWL-1700AP wireless access point.
Destek Merkezi
