Tanımlama
The D-Link ANT24-0401 connects to the DWL-900AP+, DI-614+, DI-714P+, DWL-900AP, DI-714 and DI-713P.
The D-Link ANT24-0401 antenna provides extended coverage for an existing 802.11b wireless local area network (WLAN). Using a reverse SMA connect- or, the D-Link ANT24-0401 is easily connected to the D-Link DWL-900AP+ wireless access point, DI-614+ wireless router, DI-714P+ wireless router, DWL-900AP wireless access point, DI-714 wireless router and the DI-713P wireless router Rev C1 or later wireless broadband router.
The D-Link ANT24-0401 requires an access point or wireless broadband gateway with a reverse SMA connector. The D-Link ANT24-0401 is easily connected to the DWL-900AP+ wireless access point, DI-614+ wireless router, DI-714P+ wireless router, DWL-900AP wireless access point, DI-714 wireless router and the DI-713P wireless router Rev C1 or later wireless broadband router.
Note: This product does not currently work with the enterprise DWL-1750 wireless router DWL-1700AP wireless access point.
Genel Özellikler
Elektriksel Özellikleri | |
Frekans aralığı | 2.4 -2.5GHz |
Kazanç | 4 dBi |
VSWR | 1.8:1 Max |
Polarizasyon | Doğrusal, dikey |
HPBW |
Aşağı eğim | 40° |
Güç Kullanma | 20W (cw) |
Empedans | 50 Ohms |
Konnektör | SMA dişi |
Kablo Uzunluğu | 2 Mt. |
Çevresel & Mekanik Karakteristikleri | |
Sıcaklık | -40°F ile 176°F ( -40°C ile 80°C) |
Nem | 100%@ 77°F (25°C) |
Yıldırımdan korunma | DC toprak |
Radom rengi | Beyaz |
Radom materyal | ABS |
Ağırlık | 100g |
Ebatları | 132 x 42 mm |
Rüzgar Dayanıklılığı | 180 km/sa |
Garanti | iki Yıl |
