ANT24-0401EOL EOS
Dahili 4 dBi Çok Yönlü Tavan tipi Anten
Nereden Alınır
Tanımlama
The D-Link ANT24-0401 connects to the DWL-900AP+, DI-614+, DI-714P+, DWL-900AP, DI-714 and DI-713P.
The D-Link ANT24-0401 antenna provides extended coverage for an existing 802.11b wireless local area network (WLAN). Using a reverse SMA connect- or, the D-Link ANT24-0401 is easily connected to the D-Link DWL-900AP+ wireless access point, DI-614+ wireless router, DI-714P+ wireless router, DWL-900AP wireless access point, DI-714 wireless router and the DI-713P wireless router Rev C1 or later wireless broadband router.
The D-Link ANT24-0401 requires an access point or wireless broadband gateway with a reverse SMA connector. The D-Link ANT24-0401 is easily connected to the DWL-900AP+ wireless access point, DI-614+ wireless router, DI-714P+ wireless router, DWL-900AP wireless access point, DI-714 wireless router and the DI-713P wireless router Rev C1 or later wireless broadband router.
Note: This product does not currently work with the enterprise DWL-1750 wireless router DWL-1700AP wireless access point.
Genel Özellikler
Elektriksel Özellikleri
  Frekans aralığı       2.4 -2.5GHz
  Kazanç       4 dBi
  VSWR       1.8:1 Max
  Polarizasyon       Doğrusal, dikey
  HPBW
  • Yatay - 360°
  • Dikey- 63° (each lobe, 2 lobes)
  Aşağı eğim       40°
 Güç Kullanma       20W (cw)
 Empedans       50 Ohms
  Konnektör       SMA dişi
 Kablo Uzunluğu       2 Mt.
Çevresel & Mekanik Karakteristikleri
  Sıcaklık       -40°F ile 176°F ( -40°C ile 80°C)
  Nem       100%@ 77°F (25°C)
  Yıldırımdan korunma       DC toprak
  Radom rengi      Beyaz
  Radom materyal       ABS
  Ağırlık     100g
  Ebatları      132 x 42 mm
  Rüzgar Dayanıklılığı      180 km/sa
  Garanti       iki Yıl
Fiziksel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
ANT24-0401
Front view
İndir
Destek Merkezi
