DCF-650BTEOL EOS
Bluetooth 1.1 CompactFlash Card for PDA
Nereden Alınır
Tanımlama
Exciting Upgrade for PDA
Low-power and low-cost, this card simply plugs to your PDA to deliver wireless Personal Area Network connection for your hand-held device. Very compact and lightweight, this card lets you easily talk and send data/images wirelessly from your PDAs to mobile phones, printers, desktop and laptop computers, and other emeringing electronic devices.
Bluetooth 1.1 Standard
Adhering to Bluetooth 1.1 standard, the card supports wireless data transfers of 723Kbps at ranges up to 20 meters or 66 feet. This capability allows you to establish an automatic wireless connection at a decent speed within a convenient range between your PDA and your computer, mobile phone and other devices.
723Kbps Fast Wireless Connection
As a new technology for wireless connectivity, the card lets you connect to a wide variety of devices without long cables trailing all over the place. Using a radio-based link with integrated antenna, the card connects different devices together at speed of up to 723Kbps, giving you more freedom to roam.
Data Encryption Security
Security is an issue when data is transmitted without the wires. In the air, transmitted data can be easily intercepted if not well protected by a security scheme. The card provides the necessary security, using the enhanced 128-bit data encryption on any Bluetooth communication.
Genel Özellikler
Fiziksel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DCF-650BT
Front view
İndir
Destek Merkezi
