ANT24-0800
Outdoor Omni-Directional Antenna, 8 dBi
Nereden Alınır
Tanımlama
The ANT24-0800 outdoor omni-directional antenna with 8 dBi gain operates in 2.4 GHz frequency band and has N Plug connector.
The ANT24-0800 antenna connects to a wireless device equipped with detachable external antennas, for example access point or router. The 8 dBi ANT24-0800 antenna allows you to extend the 2.4 GHz wireless network coverage and improve the quality of signal reception/transmission. This antenna is suitable both for outdoor and indoor use. Wide range of operating temperatures (-40 to 80 °C) allows you to use the antenna in harsh environmental conditions. N type connector provides compatibility with the most of outdoor access points, while the optional N Jack & RP-SMA Plug cable allows you to connect the ANT24-0800 to indoor wireless devices.
The ANT24-0800 is ideal for using a wireless device in the Point-to-Multipoint WDS/WDS+AP mode. Alternatively, Wireless Internet Service Provider (WISP) subscribers can also use this antenna to establish a strong connection between their host and their ISP’s outdoor access point.
Genel Özellikler
Connector
• N Plug
Frequency range
• 2.4 GHz ~ 2.5 GHz
Gain
• 8 dBi
VSWR
• 2.0 : 1 Max.
Polarization
• Linear, vertical
HPBW / horizontal
• 360°
HPBW / vertical
• 15°
Impedance
• 50 Ohms
Power handling
• 50 W
Lightning protection
• DC Ground
Physical parameters
Dimensions
• Diameter: 20 mm
• Length: 600 mm
Weight
• 340 g
Survival wind speed
• 180 km/hr
Operating temperature
• -40 to +80 °C
Humidity
• 100% @ 25 °C
Fiziksel Özellikler
Çözümler
Sipariş Bilgisi
ANT24-0800  Outdoor Omni-Directional Antenna, 8 dBi
Görseller
ANT24-0800/Cx
Front view
İndir
Destek Merkezi
