DWL-810+EOL EOS
Enhanced 2.4GHz (802.11b) Ethernet-to-Wireless Bridge
Tanımlama
D-Link announces another great addition to the D-Link AirPlus™ series of high-speed wireless networking products capable of transfer rates up to 22Mbps—the DWL-810+ Ethernet-to-Wireless Bridge.
The D-Link AirPlus DWL-810+ converts virtually any Ethernet device—a set-top box, game console, printer, a laptop or a desktop computer—to a wireless network device. Now Ethernet-enabled printers can be shared in the home or office without stringing cable through walls or ceilings. And gamers can join multiple-player video games with others on the Internet using a high-speed broadband connection. The DWL-810+ features advanced silicon chip design from Texas Instruments, utilizing their patented Digital Signal Processing™ technology.
With its Web-based configuration and simple setup wizard, the DWL-810+ is easy to install, enabling users to quickly connect to an existing D-Link Air, AirPlus, or other 802.11b-compliant wireless
network. And because it’s a D-Link AirPlus product, it transfers data much faster than standard 802.11b devices.
The DWL-810+ also features 256-bit WEP encryption for a higher level of security for your communication. Use this inexpensive, compact bridge to expand the number of devices and peripherals available on your wireless network.
Genel Özellikler
Standards
• IEEE 802.11
• IEEE 802.11b
• IEEE 802.3
• IEEE 802.3u
Port
10/100 Mbps Fast Ethernet
Auto MDIX
Data Rates
With Automatic Fallback
• 22Mbps    • 11Mbps
• 5.5Mbps   • 2Mbps
• 1Mbps
Encryption
64-,128-, 256-bit RC4
Media Access Control
CSMA/CA with ACK
Frequency Range
2.4GHz to 2.4385GHz
Operating Range
Indoors: Up to 328 ft (100m)*
Outdoors: Up to 1,312 ft (400m)
Modulation Technology
• PBCC - Packet Binary
   Convolutional Coding
• Direct Sequence Spread
   Spectrum (DSSS)
•11-chip Barker sequence
Modulation Techniques
• Barker (1Mbps/0db)
• Barker (2Mbps/3db)
• CCK (5.5 Mbps/5.5db)
• PBCC (5.5Mbps/1.5db)
• CCK (11Mbps/8.5db)
• PBCC (11Mbps/4.5db)
• PBCC (22Mbps/8.5db)
Power Input
External Power Supply
DC 5V, 2.5A
LEDs
• Power (Green)
• WLAN (Yellow)
Transmitter Output Power
15dBm ± 2dB
External Antenna Type
Detachable 1.0dB gain with reverse
SMA connector
Over-Driving Levels
Tolerates up to +17dBm at the antenna
Device Management
Web-Based – Internet Explorer v6 or later; Netscape Navigator v6 or later; or other Java-enabled browsers.
Çözümler
Sipariş Bilgisi
DWL-810+  Enhanced 2.4GHz (802.11b) Ethernet-to-Wireless Bridge
Görseller
DWL-810+/A
Front view
İndir
Destek Merkezi
