Hızlı Arama
Ürün Özellikleri:
Tri-Mode Dualband 802.11a/b/g (2.4/5GHz) Wireless PCI Adapter
EOL
Genel Özellikler:
Standards
• IEEE 802.11a
• IEEE 802.11b
• IEEE 802.11g-Draft
Bus Type
• PCI 2.2
• PCI 32-bit Interface
Data Rates
With Automatic Fallback
• 54Mbps • 48Mbps • 36Mbps
• 24Mbps • 18Mbps • 12Mbps
• 11Mbps  • 9Mbps • 6Mbps
• 5.5Mbps • 2Mbps • 1Mbps
Security
• 64-, 128-WEP
• 802.1x1
• WPA1—Wi-Fi Protected Access (64-, 128-WEP with TKIP, MIC, IV Expansion, Shared Key Authentication)
• Supports Advanced Encryption Standard (AES)
Media Access Control
CSMA/CA with ACK
Frequency Range
• 2.4GHz to 2.5GHz
• 5.150GHz to 5.850GHz
Range2
Indoors: Up to 328 feet (100 meters)
Modulation Technology
• Orthogonal Frequency Division Multiplexing (OFDM)
• Complementary Code Keying  (CCK)
• Direct Sequence Spread Spectrum (DSSS)
Transmitter Output Power
15dBm ± 2dB
Internal Antenna Type
Omni Directional Dipole Antenna with 2~4 dbi gain
Receiver Sensitivity
• 54Mbps OFDM, 10% PER,-73dBm)
• 48Mbps OFDM, 10% PER,-76dBm)
• 36Mbps OFDM, 10% PER,-82dBm)
• 24Mbps OFDM, 10% PER,-85dBm)
• 18Mbps OFDM, 10% PER,-88dBm)
• 12Mbps OFDM, 10% PER,-89dBm)
• 11Mbps CCK, 8% PER,-91dBm)
• 9Mbps OFDM, 10% PER,-90dBm)
• 6Mbps OFDM, 10% PER,-91dBm)
• 5.5Mbps CCK, 8% PER,-92dBm)
• 2Mbps QPSK, 8% PER,-93dBm)
• 1Mbps BPSK, 8% PER,-94dBm)
Fiziksel Özellikler
Operating Voltage
3.3 VDC ±10%
Operating Temperature
32°F to 149°F ( 0°C to 55°C)
Humidity
95% maximum (non-condensing)
Dimensions
• L = 6.6 (168mm)
• W = 4.2 (107mm)
• H = 0.16 inches (4mm)
Weight
0.17 lb (77g)
Certifications
• FCC part 15b
Warranty
3 Year
Supported Operating Systems
• Windows 98 SE
• Windows ME
• Windows 2000
• Windows XP
1 Driver or firmware upgrade download available Spring 2003
2 Environmental factors may adversely affect wireless signal range
Ürünler | Destek  | Haberler  | Hakkında |
