Hızlı Arama
Ürün Özellikleri:
Wireless 108 G PCI Card
EOL EOS
Genel Özellikler:
SYSTEM REQUIREMENTS
+  Windows 98 SE, ME, XP SP2, 2000 SP4, or Vista
+  CD-ROM drive
+  20MB hard disk space
+  Available PCI slot
STANDARDS
+  IEEE 802.11g
+  PCI 2.3
MEDIA ACCESS CONTROL PROTOCOL
+  CSMA/CA with ACK
NETWORK ARCHITECTURE TYPES
+  Ad-Hoc mode
+  Infrastructure mode
FREQUENCY RANGE
+  2.4 - 2.4835 GHz
OPERATING CHANNELS
+  US (FCC): 11
+  Europe (ETSI): 13
+  Canada (DOC): 11
NETWORK TRANSFER RATE1/MODULATION TECHNIQUE
+  802.11b: 11Mbps, 5.5Mbps: CCK
   2Mbps: DQPSK 1Mbps: DBPSK
+  802.11g: 54Mbps, 48Mbps, 36Mbps, 24Mbps, 18Mbps, 12Mbps, 9Mbps, 6Mbps: OFDM
   (Orthogonal Frequency Division Multiplexing)
RECEIVE SENSITIVITY
(FOR 802.11B)
+  1Mbps: -92dBm
+  2Mbps: -88dBm
+  5.5Mbps: -86dBm
+  11Mbps: -84dBm
RECEIVE SENSITIVITY
(FOR 802.11G)
+  6Mbps: -88dBm
+  9Mbps: -85dBm
+  12Mbps: -85dBm
+  18Mbps: -81dBm
+  24Mbps: -77dBm
+  36Mbps: -73dBm
+  48Mbps: -71dBm
+  54Mbps: -70dBm
TRANSMIT OUTPUT POWER
(FOR 802.11B)
+  1Mbps, 2Mbps, 5.5Mbps, 11Mbps: 16dBm to 18dBm
(FOR 802.11G)
+  6Mbps, 9Mbps, 12Mbps, 18Mbps, 24Mbps: 16dBm to 18dBm
+  36Mbps: 15dBm to 17dBm
+  48Mbps: 14dBm to 16dBm
+  54Mbps, 108Mbps: 13dBm to 15dBm
ANTENNA
+  External dipole antenna with detachable reverse SMA connector
OPERATING RANGE 2
+  Indoors: Up to 100 meters (328 feet)
+  Outdoors: Up to 400 meters (1,312 feet)
SECURITY
+  64/128/152-bit WEP data encryption
+  WPA EAP/PSK, WPA2 EAP/PSK
+  TKIP, AES support
Fiziksel Özellikler
DIAGNOSTIC LEDS
+  Link
+  Activity
OPERATING VOLTAGE
+  3.3V
POWER CONSUMPTION
+  Transmit mode: 248 mA
+  Power save mode: 28 mA
+  Standby mode: 4.66 mA
DIMENSIONS
+  Standard Bracket: 120mm (L) x 125mm (W) x 19mm (H) (4.72” x 4.92” x 0.75”)
+  Short Bracket: 80mm (L) x 125mm (W) x 19mm (H) (4.64” x 3.15” x 0.34”)
WEIGHT
+  55 grams (0.12 lb.)
OPERATING TEMPERATURE
+  Operating: 0º - 55º C (32º - 149º F)
+  Storage: 20º - 65º C (-4º - 149º F)
HUMIDITY
+  Up to 95% non-condensing
EMISSION (EMI)
+  FCC Class B
+  CE Class B
+  R&TTE
1 54Mbps maximum wireless signal rate derived from IEEE standard 802.11g specifcations. 108Mbps Turbo speed when operating with other D-Link Wireless 108 G products. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffc, building materials and construction, and network overhead, may lower actual data throughput rate.
2 Environmental factors will adversely affect wireless signal range.
Ürünler | Destek  | Haberler  | Hakkında |
