Hızlı Arama
Ürün Özellikleri:
802.11g Wireless LAN PCI Card
EOL EOS
Genel Özellikler:
Hardware
System Requirements
- Computer with available PCI extension bus slot
- Windows XP , 2000, ME or 98 SE
- 300MHz CPU or above
- 32MB memory or more
Wireless LAN Standards
- 802.11b
- 802.11b+
- 802.11g
PCI Bus Standard
PCI 2.2
Data Rates
- 802.11g: up to 54Mbps (6/9/12/18/24/36/48/54Mbps)
- 802.11b+: up to 22Mbps
- 802.11b: up to 11Mbps (1/2/5.5/11Mbps)
Transmission Technology
DSSS
RF Frequency Range
2.4 to 2.4835GHz
Frequency Stability
Within +/- 25ppm
Operating Channels
- 1 to 11 channels (North America)
- 1 to 13 channels (Europe)
Data Modulation Type
DBPSK, DQPSK, CCK, PBCC and OFDM (BPSK/QPSK/16-QAM/64-QAM)
Antenna
2dBi Gain detachable external antenna (reverse SMA connector)
Transmit Output Power
- 802.11b: 16dBm (typical)
- 802.11g: 14dBm (typical)
Receive Sensitivity (for 802.11b)
(typically @PER < 8% packet size 1024 @ 25  C +/- 5  C)
- 22Mbps (PBCC): -80dBm
- 11Mbps (PBCC): -85dBm
- 11Mbps (CCK): -84 dBm
- 5.5Mbps (CCK): -87 dBm
- 2Mbps (QPSK): -90 dBm
- 1Mbps (BPSK): -92 dBm
Receive Sensitivity (for 802.11g)
- 54Mbps (OFDM): -71 dBm
- 48Mbps (OFDM): -72 dBm
- 36Mbps (OFDM): -77 dBm
- 24Mbps (OFDM): -80 dBm
- 12Mbps (OFDM): -86 dBm
- 9Mbps (OFDM): -87 dBm
- 6Mbps (OFDM): -89 dBm
Operating Range *
- Indoors: 100 meters (328 feet)
- Outdoors: 400 meters (1,312 feet)
* Environmental factors may adversely affect range
Diagnostic LED
Wireless Link/Act
Software Features
Network
- Auto-switch to select 802.11g or 802.11b mode
- Supports Ad-Hoc, Infrastructure WLAN network
- Wireless roaming
- Data rate auto fall-back under noisy environment or longer range distance
- Site Survey with Profile function
Security
- WEP 64/128/256-bit data encryption (user-selectable)
- 802.1x security (MD5 and TLS) (in Windows XP only)
- Wi-Fi  Protected Access
Configuration & Management
- Plug-and-Play setup and installation
- Management Utility supports Windows 98SE, ME, 2000, XP
Fiziksel Özellikler
Power Supply
3.3 VDC +/- 5%
Power Consumption (802.11g)
- Transmit: 650mA
- Receive: 450mA
- Stand-by 20mA
Power Consumption (802.11b)
- Transmit: 500mA
- Receive: 450mA
- Stand-by: 20mA
Dimensions
134 x 121 x 22 mm
Weight
92 grams
Operating Temperature
0  to 55  C
Storage Temperature
-20  to 65  C
Humidity
5% to 95% non-condensing
Regulation Compliance
- US: FCC Part 15 Class B
- Europe: CE/R&TTE
Box Includes
- DWL-G520+ wireless PCI card
- CD (includes drivers, user's manual, Quick Installation Guide, Acrobat Reader 5.0)
- Quick Installation Guide (printed)
Ürünler | Destek  | Haberler  | Hakkında |
