Hızlı Arama
Ürün Özellikleri:
Wireless 108 G CardBus Adapter
EOL
Genel Özellikler:
System Requirements
- 32-bit CardBus slot
- 300MHz processor and 32MB memory (minimum)
Standards
802.11g wireless LAN
Adapter Type
PC Card Type II CardBus
Media Access Control Protocol
CSMA/CA with ACK
Network Architecture Types
- Ad-Hoc mode
- Infrastructure mode
Frequency Range
2.4 - 2.4835 GHz
Operating Channels
- US (FCC): 11
- Europe (ETSI): 13
- Canada (D)C): 11
Network Transfer Rate/Modulation Technique
- 802.11b:
  11Mbps, 5.5Mbps: CCK
  2Mbps: DQPSK
  1Mbps: DBPSK
- 802.11g:
  54Mbps, 48Mbps, 36Mbps, 24Mbps, 18Mbps, 12Mbps, 9Mbps, 6Mbps:
  OFDM (Othogonal Frequency Division Multiplexing)
Receive Sensitivity (for 802.11b)
- 1Mbps: -92dBm
- 2Mbps: -88dBm
- 5.5Mbps: -86dBm
- 11Mbps: -84dBm
Antenna
Internal patch antenna supporting diversity
Operation Range
- Indoors: up to 100 meters (328 feet)*
- Outdoors: up to 400 meters (1,312 feet)*
* Environmental factors may adversely affect range
Receive Sensitivity (for 802.11g)
- 6Mbps: -88dBm
- 9Mbps: -85dBm
- 12Mbps: -85dBm
- 18Mbps: -81dBm
- 24Mbps: -77dBm
- 36Mbps: -73dBm
- 48Mbps: -71dBm
- 54Mbps: -70dBm
Transmit Output Power (for 802.11b)
1Mbps, 2Mbps, 5.5Mbps, 11Mbps: 16dBm to 18dBm
Transmit Output Power (for 802.11g)
- 6Mbps, 9Mbps, 12Mbps, 18Mbps, 24Mbps: 16dBm to 18dBm
- 36Mbps: 15dBm to 17dBm
- 48Mbps: 14dBm to 16dBm
- 54Mbps, 108Mbps: 13dBm to 15dBm
Security
- 64/128/152-bit WEP data encryption
- WPA EAP, WP A PSK
Fiziksel Özellikler
Diagnostic LEDs
- Link
- Activity
Operating Voltage
3.3V
Power Consumption
- Transmission: 500 mA (max.)
- Reception: 380 mA (max.)
Dimensions
118 (L) x 54 (W) x 7.4 (H) mm
(4.64 x 2.13 x 0.29 inches)
Operating Temperature
0 -  55 C (32  -  131 F)
Storage Temperature
-20 - 75 C (-4  - 167  F)
Humidity
Up to 95% non-condensing
Emission (EMI)
- FCC Class B
- CE Class B
Ürünler | Destek  | Haberler  | Hakkında |
