DWL-2000AP+EOL EOS
802.11g High-Speed Wireless Access Point
Nereden Alınır
Tanımlama
Up to 54Mbps Speed on 2.4GHz Frequency Band
Providing transmission speeds of up to 54Mbps, the DWL-2000AP+ compares favorably with 802.11b devices that offer 11Mbps speed, and with 802.11b+ equipment that gives 22Mbps transmission. This enhanced speed and adoption of 2.4GHz frequency, now available for public use in most countries, plus the mobility and convenience inherent in a wireless LAN, make this device an ideal solution for bandwidth intensive WLAN applications.
Real Throughput 10 Times Faster Than 802.11b
Apart from the higher theoretical network data transfer speed of 54Mbps for 802.11g against the 11Mbps for 802.11b, the DWL-2000AP+ also delivers a much faster data transmission than other wireless LAN devices. In a typical working environment with multiple users accessing the network at the same time, the DWL-2000AP+ operates at 10 times the speed of the normal 802.11b wireless LAN
equipment, which is made possible by means of a turbo engine firmware inside this AP.
Wireless LAN
802.11g's compatibility with existing wireless LAN standards means that you do not need to change your entire network to maintain connectivity. The DWL-2000AP+ can transmit data at up to 54Mbps when used with D-Link AirPlusXtremeG+  and other 802.11g products.
Built-in Bridge Functions
The DWL-2000AP+ can be configured to operate in any one of the 4 modes: (1) as a wireless access point (AP), (2) a point to point wireless bridge, (3) a point to multi point wireless bridge, or (4) a wireless client. With these built-in functions, the DWL-2000AP+ gives you the flexibility to configure the device to meet your environment's requirements.
Easy Migration to Higher Bandwidth
By maintaining compatibility with your existing wireless network equipment, the DWL-2000AP+ lets you upgrade to a higher speed at the pace you want. The DWL-2000AP+ and other 802.11g standard devices can be gradually added to your network, while the rest of your older network remains perfectly connected.
Embedded DHCP Server
The DWL-2000AP+ includes an embedded DHCP server that, once enabled, will automatically assign IP addresses to wireless clients. This unique feature makes the DWL-2000AP+ an ideal solution for quickly creating and extending a wireless local area network (WLAN) in offices or other workplaces, and at trade shows and other special events.
Genel Özellikler
Wireless LAN Standards
- 802.11b
- 802.11b+
- 802.11g
Data Rates
- 802.11g: up to 54Mbps (6/9/12/18/24/36/48/54Mbps)
- 802.11b+: up to 22Mbps
- 802.11b: up to 11Mbps (1/2/5.5/11Mbps)
Transmission Technology
DSSS
RF Frequency Range
2.4 to 2.4835GHz
Frequency Stability
Within +/- 25ppm
Operating Channels
- 1 to 11 channels (North America)
- 1 to 13 channels (Europe)
Data Modulation Type
DBPSK, DQPSK, CCK, PBCC and OFDM (BPSK/QPSK/16-QAM/ 64-QAM)
Antennas
- 1 external dipole antenna, 2dBi Gain
- 1 internal embedded antenna
Transmit Output Power
- 802.11b: 16dBm (typical)
- 802.11g: 14dBm (typical)
Receive Sensitivity (for 802.11b)
(typically @PER < 8% packet size 1024 @ 25 C +/- 5  C)
- 22Mbps (PBCC): -80dBm
- 11Mbps (PBCC): -85dBm
- 11Mbps (CCK): -84 dBm
- 5.5Mbps (CCK): -87 dBm
- 2Mbps (QPSK): -90 dBm
- 1Mbps (BPSK): -92 dBm
Receive Sensitivity (for 802.11g)
- 54Mbps (OFDM): -71 dBm
- 48Mbps (OFDM): -72 dBm
- 36Mbps (OFDM): -77 dBm
- 24Mbps (OFDM): -80 dBm
- 12Mbps (OFDM): -86 dBm
- 9Mbps (OFDM): -87 dBm
- 6Mbps (OFDM): -89 dBm
Operating Range *
- Indoors: 100 meters (328 feet)
- Outdoors: 400 meters (1,312 feet)
* Environmental factors may adversely affect range
Ethernet Interface
10/100BASE-TX port with auto MDI/MDIX support
Diagnostic LEDs
- Power
- LAN
- WLAN
Software Features
Operating Modes
- Standard Access Point
- AP Client
- Bridge: Point-to-Point, Point-to-Multi Point
Security
- WEP user-selectable 64/128/256-bit data encryption
- Password protect
- 802.1x security (MD5 and TLS)
- MAC filtering
- SSID broadcast disable
- Wi-Fi  Protected Access
Configuration & Management
- DHCP client/server
- Management Utility supports Windows 98SE, ME, 2000, XP
- Status log
Configuration Reset
Default reset button
Fiziksel Özellikler
Power Supply
- 5 VDC +/- 5%, 2.5A
- Through external power adapter
Dimensions
142 x 109 x 31 mm (device only)
Weight
243 grams (device only)
Operating Temperature
0 to 55  C
Storage Temperature
-20  to 65  C
Humidity
5% to 95% non-condensing
Regulation Compliance
- US: FCC Part 15 Class B
- Europe: CE/R&TTE
Box Includes
- DWL-2000AP+ wireless LAN AP
- CD (includes AP Manager software, user's manual, Quick Installation Guide, Acrobat Reader 5.0)
- Quick Installation Guide (printed)
- 1.8 m Ethernet cable
- External power adapter
- Mounting kit
- Rubber feet
Çözümler
Sipariş Bilgisi
DWL-2000AP+   802.11g Wireless LAN Access Point
Görseller
DWL-2000AP+
Front view
İndir
Destek Merkezi
