DWL-520+EOL EOS
Tanımlama
Enhanced Speed Transmission
At 22 Megabits per second, the DWL-520+ delivers high data transfer rate within the industry standard. This speed is double the 11Mbps normally found among IEEE 802.11b 2.4GHz wireless LAN devices.
Industry-standard Interoperability
With both WiFi certification compatibility and IEEE 802.11b wireless LAN industry standard compliance, the DWL-520+ adapter provides you with excellent network interoperability.
Network Security
Security is an issue when data is transmitted without the wires. In the air, transmitted data can be easily intercepted if not well protected by a security scheme. The DWL-520+ provides the necessary security, using the enhanced 64/128/256-bit industry-standard WEP (Wired Equivalent Privacy) encryption protocol. Data privacy mechanism is based on a shared key algorithm, as described in the wireless
LAN standard.
Easy Installation
With PCI plug-and-play installation, the DWL-520+ can be easily installed into a desktop PC to provide connectivity directly to another 802.11b wireless enabled device (ad-hoc mode) or through an 802.11b Access Point (infra-structure mode).
The DWL-520+ is equipped with an SMA reverse detachable dipole antenna with an effective range of 100 meters indoors, or 400 meters outdoors. Where a longer range is required, you can easily remove this antenna and replace it with a higher Gain antenna.
Genel Özellikler
LAN Standard
- IEEE 802.11b wireless LAN
Bus Type
- PCI 2.2 specifications
- 32-bit Bus Master data transfer mode
Media Access Control Protocol
CSMA/CA
Network Architecture Types
- Supports Ad-Hoc and Infrastructure Modes
- Cell to cell roaming (IEEE 802.11b compliant)
Data Rates
- 22 Mbps
- 11 Mbps
- 5.5 Mbps
- 2 Mbps
- 1 Mbps
- Auto fallback
Data Rate & Modulation
- 22Mbps: PBCC
- 11Mbps: PBCC or CCK
- 5.5Mbps: PBCC or CCK
- 2Mbps: Barker
Operating Channels
- North America (FCC): 11
- Canada (DOC): 11
- Europe (ETSI): 13 (Except Spain and France)
- Japan (MKK): 14
Sensitivity @ PER 0.08
- 22Mbps -80dBm (PBCC)
- 11Mbps -84dBm (PBCC)
- 5.5Mbps -86dBm (CCK)
- 2 Mbps -89dBm (CCK)
- 1 Mbps -91dBm (CCK)
Frequency Range
2.4 - 2.4835 GHz
Modulation Techniques
- Direct Sequence Spread Spectrum (DSSS)
- Packet Binary Convolutional Coding (PBCC)
- 11-chip Barker Sequence
Key Management
Automatic Dynamic Key Allocation (ADKA) through public key
Data Security
64, 128, 256-bit WEP (Wired Equivalent Privacy) encryption
Antenna
Detachable 2dBi Gain dipole antenna (reverse SMA connector)
Mobility
Seamless roaming across cell boundaries within access point range
Transmitter Output Power
15dBm 2dB
Over-Driving Levels
Tolerates up to 17dBm at the Antenna
Range Coverage (Open Environment)
- Indoors: Up to 100 meters (328 feet)*
- Outdoors: Up to 400 meters (1,312 feet)*
* Environmental factors may adversely affect operating range
Çözümler
Sipariş Bilgisi
DWL-520+ 802.11b+ Wireless LAN PCI Card
