DWL-2700APEOL EOS
Tanımlama
The DWL-2700AP wireless G outdoor access point is an outdoor device with dual high Gain antennas that covers a large operating distance. This device is ideal for Internet Service Providers to create hot spot networks to provide outdoor users with wireless Internet access. It can also be installed at manufacturing plants, industrial locations, convention halls, school campuses, airports, golf courses,
marinas and other outdoor venues.
Powerful & Durable Outdoor Solution
The DWL-2700AP is designed to handle a wide variety of outdoor environments. IP 68 top level protection. It has a die-cast watertight housing, a built-in heater and a temperature sensor. Supporting Power over Ethernet (PoE), it can be placed at outdoor locations where power outlets are not easily accessible. Besides functioning as an AP, this device can be can be confgured to operate as a Wireless Distribution System (WDS) to act as a bridge linking together networks in different buildings.
Advanced Network Security
The DWL-2700AP supports 64/128/152-bit WEP data encryption and WPA/WPA2 security functions. In addition, it provides MAC Address Filtering to control user access, and the Disable SSID Broadcast function to limit outsiders’ access to the internal network.
Network Flexibility and Effciency
The DWL-2700AP supports up to 8 SSID, allowing the administrators to logically divide the access point into several virtual access points all within a single hardware platform. Rather than having two separate networks with two access points, administrators can deploy one single AP to support more than one application, such as public Internet access and internal network control to increase fexibility and keep costs down. The DWL-2700AP supports 802.1Q VLAN Tagging, operating with multiple SSID to segment traffc to enhance performance and security.
The DWL-2700AP provides WLAN STA partitioning, a function useful for deployments like at hot spots. With station-to-station partitioning enabled, security is enhanced, since wireless users cannot peek at each other, and the possibility for data thievery is reduced. Administrators can, however, disable this function, so wireless users at an offce can share hard disks and
information, and peripherals such as wireless printers. The DWL-2700AP also supports AP grouping, allowing several access points to balance wireless network traffc and wireless clients among the AP with the same SSID and different non-overlapping frequency channels.
Network Management
Network administrators can manage DWL-2700AP’s settings via web-based confguration or Telnet. Administrators can use a Windows-based utility called AP Manager to automatically discover all wireless devices installed on the network and do bulk confguration of multiple AP to save time and effort.
Genel Özellikler
Standards:
+ IEEE 802.11b/g WLAN
+ IEEE 802.3/802.3u Ethernet
+ IEEE 802.3x Flow Control
Ethernet Interface:
+ 10/100BASE-TX Ethernet port
Radio and Modulation Type:
For 802.11b:
DSSS:
+ DBPSK @ 1Mbps
+ DQPSK @ 2Mbps
+ CCK @ 5.5 and 11Mbps
For 802.11g:
OFDM:
+ BPSK @ 6 and 9Mbps
+ QPSK @ 12 and 18Mbps
+ 16QAM @ 24 and 36Mbps
+ 64QAM @ 48 and 54Mbps
DSSS:
+ DBPSK @ 1Mbps
+ DQPSK @ 2Mbps
Operating Frequency:
+ 2400 to 2483.5MHz
Channel Numbers:
+ 11 Channels (FCC)
+ 13 Channels (ETSI)
Data Rates:
+ 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6Mbps
+ 802.11b: 11, 5.5, 2, and 1Mbps
Transmit Output Power 3
For 802.11b:
+ 100mW (20dBm) + 50mW (17dBm)
+ 30mW (15dBm) + 20mW (13dBm)
+ 10mW (10dBm)
+ 5mW (7dBm) + 1mW (0dBm)
For 802.11g:
+ 200mW (23dBm) + 63mW (18dBm)
+ 10mW (10dBm) + 5mW (7dBm)
+ 1mW (0dBm)
Receive Sensitivity:
For 802.11b:
+ 1Mbps: -92dBm + 2Mbps: -89dBm
+ 5.5Mbps: -88dBm + 11Mbps: -83dBm
For 802.11g:
+ 5.5Mbps: -88dBm + 6Mbps: -87dBm
+ 9Mbps: -86dBm + 11Mbps: -85dBm
+ 12Mbps: -88dBm + 18Mbps: -83dBm
+ 24Mbps: -80dBm + 36Mbps: -76dBm
+ 48Mbps: -71dBm + 54Mbps: -66dBm
Antennas:
Dual 5dBi Gain Reverse-N Type dipole antennas
Wireless Operating Range4
802.11g (Full Power with 5dBi gain diversity dipole antennas):
Indoor:
+ 30 m (98 ft) @ 54Mbps + 34 m (112 ft) @ 48Mbps
+ 56 m (184 ft) @ 18Mbps + 66 m (217 ft) @ 12Mbps
+ 79 m (259 ft) @ 9Mbps + 99 m (325 ft) @ 6Mbps
Outdoor:
+ 112 m (367 ft) @ 54Mbps + 250 m (820 ft) @ 18Mbps
+ 500 m (1,640 ft) @ 6Mbps
Security:
+ 64/128/152-bit WEP data encryption
+ WPA-PSK, WPA2-PSK
+ WPA-EAP, WPA2-EAP
+ TKIP, AES support
+ MAC address filtering user access
+ WLAN STA partitioning
+ Multiple SSID for network segmentation
+ SSID broadcast disable function
+ 802.1Q VLAN Tagging
Configurable Modes:
+ Access Point
+ WDS With AP
+ WDS
Performance Enhancement:
+ AP grouping for load balance
Device Management:
Web Browser Interface:
+ HTTP
+ Secure HTTP (HTTPS)
AP Manager
SNMP support:
+ D-View module
+ Private MIB
Command Line Interface:
+ Telnet
+ Secure (SSH) Telnet
Diagnostic LEDs:
+ Power LED + 10/100Mbps + 802.11b/g
Accessories Provided for Outdoor Installation:
+ 2 surge arrestors
+ PoE base unit
+ RF jumper cable (1 meter long)
+ Ethernet cable (30 meters long)
+ Set of grounding wires
+ 2 mounting kits
Operating Voltage:
48VDC +/- 10% for PoE
Power Consumption:
+ 8.5 watts (max.) with PoE (with heater OFF)
+ 28.5 watts (max.) with PoE (with heater ON) 1
Dimensions:
+ 277.7 (L) x 155 (W) x 45 (H) mm (10.93 x 6.10 x 1.77 inches)
Weight:
+ 1.82 kg (4.1 lbs)
Operating Temperature:
+ -40˚ to 60˚ C (-40˚ to 140˚ F)
Storage Temperature:
+ 40˚ to 65˚ C (-40˚ to 149˚ F)
Operating Humidity:
+ 5% to 95% non-condensing, all-weather enclosure
Regulation Certification:
+ FCC Class
+ CE
+ IP 68
+ C-Tick
1 Power consumption may exceed 802.3af PoE standard when heater is in operation; connect this device through the included PoE Base Unit.
2 Maximum wireless signal rate based on IEEE 802.11g specifications. Actual data throughput will vary. Network conditions and environmental factors, including
volume of network traffic, building materials and construction, and network overhead may lower actual data throughput rate.
3 Maximum power setting will vary according to individual country regulations.
4 Environmental factors may adversely affect operation range.
