Tanımlama
Range Extension of up to 100 Meters
Repeater signals are provided when this device is deployed in conjunction with either a wireless router or a second access point. The device can receive signals from a wireless router or access point up to 100 meters (328 feet) away, then rebroadcasts the signals to wireless clients beyond the edge of the original network.
Two Operation Modes: Repeater and Access Point
The device can operate in two different modes: the repeater and the access point mode. This makes it a convenient device that can be installed as an access point at homes or offices with normal wireless operation range requirements, or as a repeater when the number of wireless users increases and spreads in a wider area.
This device works seamlessly with D-Link AirPlus DI-614+ enhanced wireless router; the AirPlus DI-714P+ enhanced wireless router with print server, the AirPro DI-764 multimode wireless router, the AirPro DI-754 multimode wireless router with the DWL-650+, and the AirPremier DWL-1000AP+ enterprise wireless access point.
Ideal for Large Homes and Buildings
Strictly complying to industry standards, this device gives you transmission speeds of up to 22Mbps, 256-bit enhanced security, extended wireless range and interoperability with 802.11b wireless LAN equipment and Ethernet-based networks, ideal for use in large homes and buildings.
Network Security
Security is an issue when data is transmitted without the wires. In the air, transmitted data can be easily intercepted if not well protected by a security scheme. This device provides the necessary security, using the enhanced 64/128/256-bit industry-standard WEP (Wired Equivalent Privacy) encryption protocol. Data privacy mechanism is based on a shared key algorithm, as described in the wireless LAN standard.
Detachable Antenna
This device is equipped with a detachable omni directional antenna with an effective range of 100 meters indoors, or 400 meters outdoors. Connected through a standard reverse SMA connector, this antenna can be easily removed and replaced it with a higher Gain antenna when a longer range is required.
Genel Özellikler
Standarts
- IEEE 802.11b wireless LAN
- IEEE 802.3 10BASE-T Ethernet
- IEEE 802.3u 100BASE-TX Fast Ethernet
Reception Sensitivity Nominal Temp Range
- 22Mbps: 10-5 BER @ -80 dBm minimum
- 11Mbps: 10-5 BER @ -79 dBm minimum
- 5.5Mbps: 10-5 BER @ -83 dBm minimum
- 1Mbps: 10-5 BER @ -89 dBm minimum
Data rates
- 22Mbps
- 11Mbps
- 5.5Mbps
- 2Mbps
- 1Mbps
- Auto fall-back
Frequency Range
- 2.4 - 2.4835 GHz
Modulation Technique
- PBCC
- DSSS
- 11-chip Barker sequence
Data Rate & Modulation
- 22Mbps/8.5db: PBCC
- 11Mbps/4.5db: PBCC
- 11Mbps/8.5db: CCK
- 5.5Mbps/1.5db: PBCC
- 5.5Mbps/5.5db: CCK
- 2Mbps/3db: Barker
- 1Mbps/0db: Barker
Operating Channels
- North America (FCC):11
- Canada (DOC): 11
- Europe (ETSI): 13
- Japan (MKK): 14
Antenna
Detacgable external omni directional antenna (reverse SMA connector)
Operating Range
- Indoor: up to 100 m (328 feet)
- Outdoor: 400 m (1,312 feet)
Data Security
- 64-bit, 128-bit and 256-bit WEP encription
Wireless LAN to Ethernet Interface
RJ-45 10/100 Mbps Fast Ethernet ports with MDI/MDIX
Operation Modes
- Repeater
- Access Point
Configuration & Management
Web-Based through Internet Explorer v.6 or later, Netscape Navigator v.6 or later, or other Jave-enabled browsers
Diagnostic LEDs
- Power
- WLAN
Çözümler
Sipariş Bilgisi
DWL-800AP+ 802.11b+ Wireless LAN Range Extender
