Hızlı Arama
Ürün Özellikleri:
High-Speed 2.4GHz(802.11g) Wireless Cardbus Adapter
EOL
Tanımlama:
D-Link, the industry pioneer in wireless networking, introduces another performance breakthrough in wireless connectivity—the D-Link AirPlus™ G series of high-speed devices.The D-Link AirPlus G DWL-G630 Cardbus Adapter is a wireless cardbus featuring the very latest in advanced wireless silicon chip technology including enhanced security to shield and protect your wireless communication from intruders.The DWL-G630 also works with 802.11b standard wireless devices and when used with other D-Link AirPlus G products delivers throughput speeds capable of handling heavy data payloads.
The DWL-G630 features WPA and 802.1x for wireless user authentication, providing you a much higher level of security for your data and communications.
The D-Link AirPlus G DWL-G630 also includes a configuration utility to discover available wireless networks and create and save detailed connectivity profiles for those networks most often accessed.
The DWL-G630 is a powerful 32-bit Cardbus Adapter that installs quickly and easily into laptop PCs and when used with other D-Link AirPlus G products automatically connects to the network. Like all D-Link wireless adapters, the DWL-G630 can be used in Ad-Hoc mode to connect directly with other cards for peer-to-peer file sharing or in Infrastructure mode to connect with a wireless access point or router for access to the Internet in your office or home network.
1 Maximum wireless signal rate based on IEEE Standard 802.11g specifications. Actual data throughput will vary. Network conditions and environmental factors lower actual data throughput rate.
2  WPA and 802.1x requires use of the Windows® XP Zero Configuration Utility.
Ürünler | Destek  | Haberler  | Hakkında |
