Hızlı Arama
Ürün Özellikleri:
High-Speed 2.4GHz (802.11g) Wireless 108Mbps USB Adapter
EOL
Genel Özellikler:
Standards
- 802.11g wireless LAN
- 802.11b wireless LAN
Host Interface
USB 2.0
Media Access Control Protocol
CSMA/CA with ACK
Network Architecture Types
- Ad-Hoc mode
- Infrastructure mode
Frequency Range
2.4 to 2.4835 GHz
Operating Channels
- US (FCC): 11
- Europe (ETSI): 13
- Canada (DOC): 11
Radio and Modulation Schemes
- 802.11b: DQPSK, DBPSK, DSSS, and CCK
- 802.11g: BPSK, QPSK, 16QAM, 64QAM, and OFDM
Receive Sensitivity (for 802.11b)
(1000-byte PDU 8% Packet Error Rate)
-82dBm at 11Mbps
-87dBm at 2Mbps
Receive Sensitivity (for 802.11g)
(1000-byte PDU 10% Packet Error Rate)
-88dBm at 6Mbps
-86dBm at 9Mbps
-84dBm at 12Mbps
-82dBm at 18Mbps
-78dBm at 24Mbps
-74dBm at 36Mbps
-69dBm at 48Mbps
-66dBm at 54Mbps
Transmit Output Power (for 802.11b)
+16dBm at 11, 5.5, 2, and 1Mbps
Transmit Output Power (for 802.11g)
+15dBm at 54 and 48Mbps
+16dBm at 36 Mbps
+17dBm at 24, 18, 12, 9, and 6Mbps
Security
- 64/128/152-bit WEP data encryption
- WPA/WPA2 EAP , WPA/WPA2 PSK
Antenna
Internal integrated antenna
Operation Range
- Indoors: up to 100 meters *
- Outdoors: up to 300 meters *
* Environmental factors may adversely affect range
Fiziksel Özellikler
Diagnostic LEDs
- Link
- Activity
Operating Voltage
5VDC +/- 5%
Power Consumption
- Transmit mode: 472 mA
- Receive mode: 290 mA
Dimensions
81 (L) x 25 (W) x 1.3 (H) mm
Weight
150 grams (adapter only)
Operating Temperature
0  to 40 C
Storage Temperature
-20  to 75 C
Operating Humidity
20% to 80% non-condensing
Storage Humidity
5% to 95% non-condensing
Emission (EMI)
- FCC Class B
- CE Class B
- R&TTE
OS Support
- Windows 98SE, ME, 2000, XP
- Linux *
* Available in future driver upgrade
Ürünler | Destek  | Haberler  | Hakkında |
