Hızlı Arama
Ürün Özellikleri:
Wireless 108G USB Adapter
EOL
Tanımlama:
The D-Link AirPremier DWL-AG132 108AG wireless USB adapter adds high-performance 802.11a/g wireless connectivity to your desktop or notebook PC via the convenience of USB. This dualband wireless adapter enables more versatility in network deployment, which can maximize your network investment. It avoids for you the hassle of stringing Ethernet cables to your computer or dismantling your desktop PC case to insert a wireless adapter. Simply plug in the DWL-AG132 into an available USB port and enjoy the freedom of wireless networking.
Powered by D-Link 108AG technology, this wireless adapter is capable of delivering maximum wireless signal rates of up to 108Mbps when used with other D-Link 108G or 108AG devices. Dualband capability ensures that the DWL-AG132 is compatible with virtually all 802.11a/b/g networks and devices.
The DWL-AG132 wireless USB adapter is a plug and play solution. An installation wizard make simplifies device discovery and driver configuration. Thereafter, the site survey configuration utility discovers available nearby wireless networks to get you connected quickly. This utility can create detailed connectivity profiles to save and manage your most frequently accessed networks.
For accessing secure networks, this wireless USB adapter supports both WPA/WP A2-Personal and WPA/WPA2-Enterprise. Now you can utilize EAP-TLS and EAP-TTLS for secure user authentication through an 802.1x RADIUS server. Data over the air is encrypted using either TKIP. The DWL-AG132 supports also the IEEE 802.11i security specifications.
The DWL-AG132 wireless USB adapter can be used in peer-to-peer mode (ad-hoc) to directly connect to other 802.11a or 802.1 1b/g devices for direct file sharing, or in client mode (infrastructure) to connect with wireless access points or routers. It features Wi-Fi certification in all three wireless bands, 802.11a, 1 1b, and 11g, which ensures wireless compatibility and robust data encryption for sensitive data requirements.
Compact in size, this wireless 108AG USB adapter is great for travel and is a convenient solution for providing high-performance dualband wireless connectivity to your desktop or notebook PC.
Ürünler | Destek  | Haberler  | Hakkında |
