Hızlı Arama
Ürün Özellikleri:
WIRELESS G ACCESS POINT
EOL EOS
Genel Özellikler:
NETWORK STANDARDS
+  802.11g wireless LAN
+  802.11b wireless LAN
+  802.3/802.3u 10BASE-T/100BASE-TX Ethernet
+  ANSI/IEEE 802.3 NWay auto-negotiation
DEVICE INTERFACES
+  2 10/100BASE-TX Ethernet LAN ports
MEMORY
+  4MB Flash Memory
+  16MB DRAM
OPERATING FREQUENCY
+  2.4 to 2.4835 GHz
OPERATING CHANNELS
+  FCC: 11
+  ETSI: 13
RADIO & MODULATION SCHEMES
+  DQPSK, DBPSK, CCK, OFDM
OPERATION MODES
+  Access Point
+  AP Client
+  Bridge
+  Bridge with AP
+  Repeater
+  WISP Client Router
+  WISP Repeater
ANTENNA
+  2dBi Gain detachable omni-directional antenna with RP-SMA connector
NETWORK STANDARDS
DEVICE INTERFACES
MEMORY
+  4MB Flash Memory
+  16MB DRAM
OPERATING FREQUENCY
+  2.4 to 2.4835 GHz
OPERATING CHANNELS
+  FCC: 11
+  ETSI: 13
OPERATION MODES
+  Access Point
+  AP Client
+  Bridge
+  Bridge with AP
+  Repeater
+  WISP Repeater
ANTENNA
RECEIVE SENSITIVITY
+  For 802.11b, at 8% PER:
  11Mbps: -80dBm
  5.5Mbps: -84dBm
  2Mbps: -87dBm
  1Mbps: -88dBm
+  For 802.11g, at 10% PER:
  54Mbps: -65dBm
  48Mbps: -66dBm
  36Mbps: -70dBm
  24Mbps: -74dBm
  18Mbps: -77dBm
  12Mbps: -79dBm
  9Mbps: -81dBm
  6Mbps: -82dBm
TRANSMIT OUTPUT POWER
+  16dBm (typical)
SECURITY
+  64/128-bit WEP data encryption
+  WPA-PSK, WPA2-PSK
+  WPA-EAP, WPA2-EAP
+  TKIP, AES
+  MAC address fltering
+  SSID broadcast disable function
QUALITY OF SERVICE (QOS)
+  Wi-Fi Multimedia (WMM)
DEVICE MANAGEMENT
+  Web-based management through Internet Explorer v.6 or later, Netscape Navigator v.6 or later or other Java-enabled browser
Fiziksel Özellikler
DIAGNOSTIC LED
+  Power
+  Status
+  Link/Act
+  WEP/WPA
+  MAC Ctrl
+  BRIDGE / REPEATER
+  LAN1
+  LAN2
POWER INPUT
+  5VDC 2A
+  External power adapter
DIMENSIONS
+  144 (W) x 109 (D) x 30 (H) mm
  (5.67 x 4.29 x 1.18 inches)
WEIGHT
+  229grams (0.5 lb)
OPERATING TEMPERATURE
+  0˚ to 55˚ C (32˚ to 131˚ F)
STORAGE TEMPERATURE
+  -10˚ to 70˚ C (14˚ to 158˚ F)
OPERATING HUMIDITY
+  10% to 90% non-condensing
STORAGE HUMIDITY
+  5% to 95% non-condensing
CERTIFICATION
+  FCC Class B
+  CE
+  C-Tick
+  Wi-Fi
54Mbps maximum wireless signal rate derived from IEEE standard 802.11g specifcations. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffc, building materials and construction, and network overhead, may lower actual throughput rate. Environmental factors will adversely affect wireless signal range, maximum throughput based on 802.11g devices.
Ürünler | Destek  | Haberler  | Hakkında |
