Hızlı Arama
Ürün Özellikleri:
G.SHDSL Router with built-in G.SHDSL modem (Annex A, B), 10/100BASE-TX LAN port
EOL
Genel Özellikler:
DSL Standard
ITU G.991.2 (G.SHDSL) standard, Annex A, Annex B
Data Rate
Up to 2.3Mbps symmetrical
G.SHDSL Interface
- RJ-11 connector for phone line connection
- Micro filter required for analog phone set/G3 fax machine
WAN Protocols
- Bridged/Routed Ethernet over ATM (RFC 2684)
- Classical IP over ATM (RFC 1577)
- PPP over ATM protocol (RFC 2364)
- PPP over Ethernet (RFC 2516)
Signaling
- ATM signaling: UNI 3.1, 4.0
- OAM F4/F5 Loopback
IP Packet Routing
- DHCP/NAT
- IP filtering
- TCP/IP with RIP-1 and RIP-2, Static Routing
- ICMP (RFC 791)
- UDP (RFC 792)
- ARP (RFC 826)
IP Routing Protocols
- RIP-1 (RFC 1058), RIP-2 (RFC 1389)
- Static Routing
Internet Support
- Dynamic Host Configuration Protocol (DHCP) server (RFC 2131), client (RFC 2131)
- Network Address Translation (NAT)
User Authentication
- PPP Authentication Protocol (PAP) (RFC 1334)
- Challenge Handshake Authentication Protocol (CHAP) (RFC 1994)
LAN Interface
- 10/100Mbps 10BASE-T/100BASE-TX port
- Network speeds auto-sensing, full/half duplex support
Others
- Simple firewall (NAT)
- Reset button (default factory configuration reset)
Configuration/Management
- Web-based
- Telnet
Console Port
DB-9 RS-232 DCE mode, up to 9600 baud rate
Fiziksel Özellikler
LED Indicators
- Power
- Status
- DSL Link/Act
- Ethernet Link/Act
Power Input
Through external AC power adapter
Power Output
9V AC 1A
Power Consumption
5.06 watts (max.)
Operating Temperature
0 to 40 oC (32 to 104 F)
Storage Temperature
-20 to 70 C (-4 to 158 F)
Humidity
5% to 95% non-condensing
Dimensions
180 x 141 x 30 mm (device only)
Weight
350 grams (device only)
Emissions (EMI)
- FCC Class B
- CE Class B
Safety
CSA International
Ürünler | Destek  | Haberler  | Hakkında |
