Hızlı Arama
Ürün Özellikleri:
3G/ADSL/Ethernet router with Wi-Fi
EOL EOS
Genel Özellikler:
Fiziksel Özellikler
Device Interfaces:
  • ADSL: ADSL 1 port with RJ-11 connector
  • LAN: 4 10/100BASE-TX Ethernet ports with RJ-45 connector and auto MDI / MDIX
  • WLAN: Integrated Wireless 802.11b/g/n draft user interface
  • USB: Type A USB 2.0 port
Wireless network:
  • Standard IEEE 802.11n * compatibility with IEEE 802.11b / g standard equipment
  • Wireless Guest Network Support
  • WEP encryption
  • WPA/WPA2 encryption technology with TKIP, AES and TKIP + AES mechanisms
  • Access to the wireless network by MAC address
  • WPS function approaches PIN and PBC
  • Advanced Settings
ADSL standards:
  • ADSL: The multi-mode, ANSI T1.413 Issue 2, ITU-T G.992.1 (G.dmt) Annex A, ITU-T G.992.2 (G.lite) Annex A, ITU-T G.994.1 (G. hs)
  • ADSL2: ITU-T G.992.3 (G.dmt.bis) Annex A / L / M, ITU-T G.992.4 (G.lite.bis) Annex A
  • ADSL2 +: ITU-T G.992.5 Annex A / L / M
WAN connection types:
  • 3G
  • ADSL: PPPoA, PPPoE, IPoE, IPOA, Bridge
  • Ethernet: Static IP, PPPoE, DHCP
ATM / PPP Protocols:
  • ATM Adaptation Layer Type 5 (AAL5)
  • Bridged and routed Ethernet encapsulation
  • LLC (Logical Link Control) and VC-based multiplexing
  • ATM Forum UNI3.1/4.0 PVC (up to 8 PVC)
  • ITU-T I.610 OAM F4/F5 loopback
  • ATM QoS
  • PPP over Ethernet (PPPoE)
  • PPP over ATM (RFC 2364)
  • Features Keep-alive support PPP protocol
Network Protocols and Features:
  • Static IP Routing
  • NAT mechanism
  • DHCP server / client / relay
  • DNS Relay
  • Dynamic DNS (DDNS)
  • UPnP
  • VLAN Support
  • IGMP proxy
Firewall / Access Control:
  • NAT Firewall
  • MAC address filtering according to time of day and days of the week
  • Packet filtering (IP / ICMP / TCP / UDP)
  • URL Filter
  • Virtual Servers
  • Protection against DoS attacks
  • Intrusion Detection System and Event Logging
  • DMZ
  • Functions Port Triggering Support
QoS:
  • Interface with the user clustering
  • 3 priority queues
USB modem:
  • PIN verification on / off
  • PIN code change
Installation and management:
  • Web user interface in English and Russian languages
  • Software upgrade via Web user interface
  • Configuration maintenance and commissioning
  • Remote Event Log Support
  • SNMP Agent
  • Automatic system time synchronization with NTP server
Physical parameters
Meals:
  • External power supply
  • On / off button
  • Wireless connection on / off button
  • Reset Button factory settings return
  • WPS Button
* Maximum wireless connection speed is limited to 65 Mbps.
Ürünler | Destek  | Haberler  | Hakkında |
