DSL-2650UEOL EOS
3G/ADSL/Ethernet router with Wi-Fi
Nereden Alınır
Tanımlama
DSL-2650U/NRU/C - is a versatile 3G/ADSL/Ethernet router with Wi-Fi and built-in switch. The router allows you to connect to the Internet via 3G GSM network (using a 3G GSM modem 1.2 ). In addition, the device allows you to access the Internet or using ADSL and Ethernet technologies.
The router has one ADSL port for ADSL line connection and 4 Ethernet ports to connect job. Therefore DSL-2650U/NRU/C is cost effective solution to a wired network without the need for a separate switch purchase. In addition, any device Ethernet port to use a router to connect to a separate Ethernet line. The device even has a USB port which can be connected to the USB modem, printer or data collector.
The router works with 802.11n 3 standard wireless devices and is compatible with 802.11b / g standard equipment. DSL-2650U/NRU/C supports supports security standards WEP, WPA/WPA2, carry-enabled devices MAC address filtering, and allows you to use WPS technology. DSL-2650U/NRU/C has an integrated firewall. Enhanced security features reduce hackers hacking into the network and enables the possibility to restrict access to some web pages of your local network users. Device deployment and management is simple and user-friendly Web user interface (supports Russian and English languages).
1 USB modem with the device is sold. D-Link does not guarantee compatibility with all USB modems. List of supported USB modems available on our website .
2 For information on prices and services operating range please contact your operator.
3 Maximum wireless connection speed is limited to 65 Mbps.
Genel Özellikler
Fiziksel Özellikler
Device Interfaces:
  • ADSL: ADSL 1 port with RJ-11 connector
  • LAN: 4 10/100BASE-TX Ethernet ports with RJ-45 connector and auto MDI / MDIX
  • WLAN: Integrated Wireless 802.11b/g/n draft user interface
  • USB: Type A USB 2.0 port
Wireless network:
  • Standard IEEE 802.11n * compatibility with IEEE 802.11b / g standard equipment
  • Wireless Guest Network Support
  • WEP encryption
  • WPA/WPA2 encryption technology with TKIP, AES and TKIP + AES mechanisms
  • Access to the wireless network by MAC address
  • WPS function approaches PIN and PBC
  • Advanced Settings
ADSL standards:
  • ADSL: The multi-mode, ANSI T1.413 Issue 2, ITU-T G.992.1 (G.dmt) Annex A, ITU-T G.992.2 (G.lite) Annex A, ITU-T G.994.1 (G. hs)
  • ADSL2: ITU-T G.992.3 (G.dmt.bis) Annex A / L / M, ITU-T G.992.4 (G.lite.bis) Annex A
  • ADSL2 +: ITU-T G.992.5 Annex A / L / M
WAN connection types:
  • 3G
  • ADSL: PPPoA, PPPoE, IPoE, IPOA, Bridge
  • Ethernet: Static IP, PPPoE, DHCP
ATM / PPP Protocols:
  • ATM Adaptation Layer Type 5 (AAL5)
  • Bridged and routed Ethernet encapsulation
  • LLC (Logical Link Control) and VC-based multiplexing
  • ATM Forum UNI3.1/4.0 PVC (up to 8 PVC)
  • ITU-T I.610 OAM F4/F5 loopback
  • ATM QoS
  • PPP over Ethernet (PPPoE)
  • PPP over ATM (RFC 2364)
  • Features Keep-alive support PPP protocol
Network Protocols and Features:
  • Static IP Routing
  • NAT mechanism
  • DHCP server / client / relay
  • DNS Relay
  • Dynamic DNS (DDNS)
  • UPnP
  • VLAN Support
  • IGMP proxy
Firewall / Access Control:
  • NAT Firewall
  • MAC address filtering according to time of day and days of the week
  • Packet filtering (IP / ICMP / TCP / UDP)
  • URL Filter
  • Virtual Servers
  • Protection against DoS attacks
  • Intrusion Detection System and Event Logging
  • DMZ
  • Functions Port Triggering Support
QoS:
  • Interface with the user clustering
  • 3 priority queues
USB modem:
  • PIN verification on / off
  • PIN code change
Installation and management:
  • Web user interface in English and Russian languages
  • Software upgrade via Web user interface
  • Configuration maintenance and commissioning
  • Remote Event Log Support
  • SNMP Agent
  • Automatic system time synchronization with NTP server
Physical parameters
Meals:
  • External power supply
  • On / off button
  • Wireless connection on / off button
  • Reset Button factory settings return
  • WPS Button
* Maximum wireless connection speed is limited to 65 Mbps.
Çözümler
Sipariş Bilgisi
Görseller
DSL-2650U
Front view
Back view
İndir
Destek Merkezi
