DSL-2540U (ANNEX B)EOL EOS
Tanımlama
Affordable solution for
high-speed connectivity for your home or small office DSL-2540U provides all the essentials for a safe, high-speed wireless network: support for standards ADSL/ADSL2/ADSL2 +, support for the standard Fast Ethernet, built-in firewall, ensure quality data (QoS ), as well as many additional features.
Security
Router DSL-2540U has a built-in firewall. Advanced security features minimize threats of hackers and prevent intrusions to your network and access to unwanted websites for users on your local network.
ADSL-port and 4-port
ADSL-router is equipped with a port for connecting to ADSL-line and 4-port Ethernet-to connect workstations. With this DSL-2540U is a cost effective solution for wired networks without the need to install a separate switch. In addition, any Ethernet-port devices can be used to connect to a dedicated Ethernet-line.
Configuration and Management
for managing and configuring DSL-2540U uses a simple and user-friendly web-based interface (available in several languages).
