Hızlı Arama
Ürün Özellikleri:
Wireless ADSL2 + (ANNEX B) Router with Built-in 4-port switch 10/100Base-TX
EOL EOS
Genel Özellikler:
Fiziksel Özellikler
Interfaces
• ADSL: 1 port with RJ-11
• LAN: 4-port 10/100BASE-TX Ethernet with RJ-45 auto-sensing polarity of MDI / MDIX
• WLAN: built-in wireless interface standard, 802.11b, g and n draft
Wireless network
• Standard IEEE 802.11n *, compatible with current standard IEEE 802.11b / g
• Support of guest wireless network
• WEP-encryption
• WPA/WPA2 encryption technology with the mechanisms of TKIP, AES and TKIP + AES
• Access to a wireless network based on the MAC-addresses
• Methods and PIN WPS PBC function
• Advanced Settings
ADSL standards
• ADSL: ANSI T1.413-1998 Issue 2; ITU G.992.1 Annex B
• ADSL2: ITU G.992.3 Annex B
• ADSL2 +: ITU G.992.5 Annex B
Types of WAN-connection
• ADSL
  - PPPoA
  - PPPoE
  - IPoE
  - IPoA
  - Bridge
• Ethernet
  - Static IP
  - DHCP
  - PPPoE
Protocols ATM / PPP
• Ethernet encapsulation bridging and routing
• Multiplexing based on VC / LLC
• ATM Forum UNI3.1/4.0 PVC (up to 8 PVC)
• ATM adaptation layer type 5 (AAL5)
• The principles and functions of the OAM ITU-T I.610, including F4/F5 loopback
• ATM QoS
• PPP over ATM (RFC 2,364)
• PPP over Ethernet (PPPoE)
• Support for Keep-alive for PPP-protocol
Network Protocols and Features
• Static IP-routing
• The mechanism of NAT
• DHCP-server/klient/relay
• DNS relay
• Dynamic DNS (DDNS)
• UPnP
• VLAN support
• IGMP proxy
Firewall and Access Control
• NAT firewall
• Filtering by MAC-address-to the time of day and day of week
• URL-Filter
• Packet filtering (IP / ICMP / TCP / UDP)
• Virtual Servers
• Prevent DoS-attacks
• Intrusion detection and event logging
• The technology to protect DMZ
• Supports Port Triggering
QoS
Grouping interfaces
3 priority queues
Configuration and Management
• Web-based interface for configuration and management of multiple languages
• Upgrade the firmware of the router through the web-interface
• Save and load configuration
• Support for remote logging
• SNMP-agent
• Automatic synchronization of system time with a NTP-server
Fiziksel Özellikler
Nutrition
• External Power Adapter
• The power switch ON / OFF
• Switch Wireless ON / OFF
• The Reset button to restore factory default settings
• WPS Button
* Maximum wireless chipset is limited to 65 Mbit / c.
Ürünler | Destek  | Haberler  | Hakkında |
