Hızlı Arama
Ürün Özellikleri:
ADSL/ADSL2/ADSL 2 + Router
EOL EOS
Genel Özellikler:
Fiziksel Özellikler
Interfaces
• ADSL: 1 port with RJ-11
• LAN: 1 10/100BASE-TX Ethernet port with an RJ-45 auto-sensing polarity of MDI / MDIX
ADSL standards
• ADSL: ANSI T1.413-1998 Issue 2; ITU-T G.992.1 (G.dmt) Annex B, ITU-T G.992.2 (G.lite) Annex B
• ADSL2: ITU-T G.992.3 Annex B
• ADSL2 +: ITU-T G.992.5 Annex B
Types of WAN-connection
• PPPoA
• PPPoE
• IPoE
• IPoA
• Bridge
Protocols ATM / PPP
• Ethernet encapsulation bridging and routing
• Multiplexing based on VC / LLC
• ATM Forum UNI3.1/4.0 PVC (up to 8 PVC)
• ATM adaptation layer type 5 (AAL5)
• The principles and functions of the OAM ITU-T I.610, including F4/F5 loopback
• ATM QoS
• PPP over ATM (RFC 2,364)
• PPP over Ethernet (PPPoE)
• Support function Keep-alive for PPP-protocol
Network Protocols and Features
• Static IP-routing
• The mechanism of NAT
• DHCP-server/klient/relay
• DNS relay
• Dynamic DNS (DDNS)
• UPnP
• VLAN support
• IGMP proxy
• RIP
Firewall and Access Control
• NAT firewall
• URL-Filter
• Packet filtering (IP / ICMP / TCP / UDP)
• Virtual Servers
• Prevent DoS-attacks
• Intrusion detection and event logging
• The technology to protect DMZ
• Supports Port Triggering
QoS
3 priority queues
Configuration and Management
• Web-based interface for configuration and management of multiple languages
• Access via TELNET
• Upgrade the firmware of the router through the web-interface
• Save and load configuration
• Support for remote logging
• Automatic synchronization of system time with a NTP-server
• The Ping
Fiziksel Özellikler
Nutrition
• External DC power adapter 5B/1A
• The Reset button to restore factory default settings
Ürünler | Destek  | Haberler  | Hakkında |
