RSP-1000-48EOL
External power supply for DAS-4672, 1008W
Tanımlama
External Power Supply RSP-1000-48 is ideal for use with the IP DSLAM DAS-4672 D-Link, providing the necessary power settings for the proper operation of the DAS-4672.
RSP-1000-48 supports the following nominal values of characteristics: output power 1008Vt, 21A output current and the output voltage of 48V. In addition, the device has a built-in protection mechanisms against overload, over the output voltage, short circuit and high temperature.
