RSP-1000-48Proje
External power supply for DAS-4672, 1008W
Nereden Alınır
Tanımlama
External Power Supply RSP-1000-48 is ideal for use with the IP DSLAM DAS-4672 D-Link, providing the necessary power settings for the proper operation of the DAS-4672.
RSP-1000-48 supports the following nominal values ​​of characteristics: output power 1008Vt, 21A output current and the output voltage of 48V. In addition, the device has a built-in protection mechanisms against overload, over the output voltage, short circuit and high temperature.
Genel Özellikler
Fiziksel Özellikler
    Characteristics at the input
    range of input voltages
  • From 90V to 264V AC
  • From ~ 370 to 124V DC
  • Input Frequency Range AC line voltage
  • 47 Hz to 63 Hz
  • leakage current <2.0 mA at 240 V AC at the output characteristics
  • Output voltage 48VRated output current 21A output current range of 0-21A
  • Output Power
  • 1008 W
  • Built-in protective mechanisms
  • Overload protection is triggered when the value exceeds the nominal output power of 5% -35%
  • overtemperature protection of the output voltage and short-circuit is triggered when the output voltage of 56.6 V to 66.2 in
  • protection against high temperatures
  • Ventilation Built-in fan DC
  • MTBF 35,000 hours at rated voltage lines, maximum load, ambient temperature 25C
  •  Safety
    UL
  • TUV
The physical parameters
Size
295 x 127 x 41 mm Operating temperature from -20 o to +60 o C Storage temperature from -40 o to +85 oC Operating humidity 20% to 90% non-condensing Storage Humidity 10% to 95% non- Condensate
Çözümler
Sipariş Bilgisi
Görseller
RSP-1000-48
Front view
İndir
Destek Merkezi
