DAS-4672-20Proje
ADSL2+ Line Card, 48 ports
Nereden Alınır
Tanımlama
Linear unit. This module supports 48-port ADSL2 / 2 +, which allows users to connect up to 48 ADSL.
Genel Özellikler
Fiziksel Özellikler
Interfaces
48 subscriber interfaces on the module
Linear standards
• ANSI T1.413
• ITU-T G.992.1, (G.dmt) AnnexA
• ITU-T G.992.2, (G.Lite) AnnexA
• ITU-T G.994.1, (G.hs) handshake protocol
• ITU-T G.992.3, (ADSL2)
• ITU-T G.992.3, AnnexM
• ITU-T G.992.3, AnnexL (Reach Extended xDSL)
• ITU-T G.992.5, (ADSL2 +)
Support for ATM
• Up to 8 PVC on port
• OAM loop back
• RFC 2684 (Multiple Protocol over AAL5)
The physical parameters
Dimensions (width / height / depth)
400 x 24.1 x 255.1 mm
Power consumption
• Full load: 49 W
• Subscriber Port: 1.02Vt
Weight
0.95 kg
Çözümler
Sipariş Bilgisi
Görseller
DAS-4672-20
Front view
İndir
Destek Merkezi
