DMC-805XEOL
10G CX4 Media Converter for 10G SFP +
Tanımlama
Media Converter DMC-805X converts the signal from the standard 10G CX4 on the signal 10G SFP +. DMC-805X is equipped with a slot for SFP + optical transceivers, user-selectable, and extends the network connection for the different distances depending on the capabilities of SFP + transceiver. DMC-805X is a high performance media converter 10G, which allows you to increase the distance for servers equipped with network cards or old CX4 10G switches with port 10G CX4.
DMC-805X can be used as a standalone unit or mounted in a standard rack chassis (DMC-1000), and the control function will be available. Control Module (DMC-1002) allows users to monitor the status of DMC-805X and the power in the chassis in real time.It also sends alarm and alerts users of emergency situations. The control module meets the following industry standards, including SNMP and HTTP, which allows users to monitor and manage the chassis of a third-party SNMP management station or through a web-browser.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DMC-805X/A1
Back view
Front view
Front view
İndir
Destek Merkezi
