Hızlı Arama
Ürün Özellikleri:
DIR-685 Xtreme N Storage Router
EOL
Genel Özellikler:
Specifications
Standards
IEEE 802.11n
IEEE 802.11g
IEEE 802.3
IEEE 802.3u
Device Interface
4 Gigabit LAN Ports
1 Gigabit WAN Port
2 USB Ports (SharePort™ and WCN)
Antenna Type
Internal Antennas
Security
Wi-Fi Protected Access™ (WPA™, WPA2™)
Advanced Firewall Features
Network Address Translation (NAT)
Stateful Packet Inspection (SPI)
VPN Pass-through / Multi-sessions PPTP / L2TP / IPSec
LEDs
Power
LCD
Display Panel
3.2 inch TFT LCD
1.6 million colors
Configuration Management
Internet Explorer® v6 or Later; Mozilla® Firefox® v2.0 or Later; or other Java-enabled Browsers
Buttons
Touch Sensitive Navigation controls
WPS
Hard Drive Unmount
Reset
Supported Hard Drive Type
2.5 inch SATA hard drive* up to 1TB
NAS
UPnP™ AV server for streaming media to compatible media players**
Built-in FTP server for file access from over the Internet***
Scheduled downloads from Web or FTP sites
Power management for conserving energy and extending hard drive life
Real time backups with the included backup software
Multi-language file name support
Certifications
FCC Class B
IC
Wi-Fi®
Dimensions
Item (WxDxH): 4.4” x 5.8” x 1.2”
Packaging (WxDxH): 11.1” x 9.6” x 3.2”
Weight
Item: 0.5 lbs
Packaging: 2.0 lbs
Warranty
1 Year Limited****
Recommended System Requirements
For Optimal Wireless Performance:
Use with Xtreme N Adapters (DWA-552, DWA-556, DWA-643, DWA-652, or DWA-160)
Minimum System Requirements
Computer with:
Windows Vista™*****, Windows® XP SP2 or Mac OS® X (v10.4)******
Internet Explorer® v6 or Mozilla® Firefox® v2.0
CD-ROM Drive
Network Interface Card
For Internet Access:
Cable or DSL Modem
Subscription with an Internet Service Provider (ISP)
Package Contents
CAT5 Ethernet Cable
Stand
Power Adapter
CD-ROM******* with:
Installation Wizard
Product Documentation
* Hard Drive(s) not included. An internal 2.5" SATA drive is required to store or share your files May not work with older generation SATA drives.
** D-Link cannot guarantee full compatibility of proper playback with all codecs. Playback compatibility depends on the codec support of the UPnP AV media player.
*** Use of an FTP Server to access files of over the Internet does not provide for secure or encrypted transmissions. It is recommended that the end-user utilize a Virtual Private Network (VPN) to establish a secure FTP session.
**** 1-Year Limited Warranty available only in the USA and Canada.
***** Computer must adhere to Microsoft's recommended System Requirements.
****** The software included with this product is not Mac-compatible. However, a SharePort utility for Mac is provided.
******* Latest software and documentation are available at D-Link Tech Support site.
All references to speed are for comparison purposes only. Product specifications, size and shape are subject to change without notice, and actual product appearance may differ from that depicted herein.
Fiziksel Özellikler
Ürünler | Destek  | Haberler  | Hakkında |
