DSR-250EOL EOS
The firewall supports VPN, WAN + 1-port 8-port LAN 10/100/1000Base-TX
Nereden Alınır
Tanımlama
Unified routers D-Link DSR series are high-performance solutions that protect the network and designed to meet the growing needs of small and medium-sized businesses. Support for IEEE 802.11n, realized in the routers DSR-150N, DSR-250N, DSR-500N, DSR-1000N, can achieve the same performance as that of wired networks, but with fewer restrictions. Optimal protection is achieved through a network of tunnels organization VPN (Virtual Private Network), protocol support IP Security (IPSec), Point-to-Point Tunneling Protocol (PPTP), Layer 2 Tunneling Protocol (L2TP), Generic Routing Encapsulation (GRE) 1 .Thanks to the VPN-tunnels sales representatives and employees of the territorial subdivisions get remote access to the corporate network from any location and at any time, without installing client software.
Integrated management capabilities
Routers and DSR-500/500N DSR-1000/1000N equipped with two WAN-Gigabit Ethernet ports and supports policy-based management, which ensures maximum productivity in business operations. Automatic switch failover (failover) ensures reliable transmission of data, including failure of one of the compounds. Application load balancing allows you to distribute outbound traffic between the two interfaces, and WAN-optimized system performance, providing thus the smooth operation of the network. The second WAN-port can be configured as a DMZ-port, allowing you to isolate servers from the LAN.
High-performance wireless network
DSR-150N, DSR-250N, DSR-500N and DSR-1000N supports 802.11a standard 5 / b / g / n and of operating in the 2.4 GHz or 5 GHz 5 . Thanks to the support of technology Multiple In Multiple Out (MIMO) routers DSR-150N, DSR-250N, DSR-500N and DSR-1000N provide high speed data transfer and enhanced wireless coverage, allowing you to reduce the number of "dead zones".
Universal installation
DSR routers support the ability to provide access to the Internet via the 3G network using the USB-modem 4 . Support for 3G networks makes it possible to connect an additional secure transmission of critical data or the stable operation of services of reservation. Routers DSR-1000/1000N 3G USB-modem can be configured as a third WAN-connection-enabled functions to automatically switch failover and load balancing in case of loss of the WAN-connection.
On routers DSR-500/500N 1 second WAN-port can be selected WAN2 or used for 3G modem with support for features like automatic switch failover and load balancing in case of loss of the WAN-connection. Routers DSR-150/150N/250/250N1 3G USB-modem can be configured as the first WAN-connection or a backup connection in case of loss of connection.
Secure VPN features
Virtual Private Network (VPN) provides mobile users and branch offices secure channel of communication to connect to the corporate network. DSR-150/150N, DSR-250/250N, DSR-500/500N DSR-1000/1000N and supports 5, 10, 15 or 20 tunnels Generic Routing Encapsulation (GRE) 1 , providing mobile users with remote access to a central corporate database . When you create a Site-to-site VPN-tunnel protocols are IP Security (IPSec), Point-to-Point Tunneling Protocol (PPTP) or Layer 2 Tunneling Protocol (L2TP), which simplifies the process of connecting remote users and branch offices through encrypted virtual links .DSR-150/150N supports up to 10 simultaneous IPSec VPN-tunnels and up to 10 VPN-tunnels PPTP/L2TP. DSR-250/250N, DSR-500/500N DSR-1000/1000N and supports up to 25, 35 and 70 simultaneous IPSec VPN-tunnels, respectively, as well as 25 additional VPN-tunnels PPTP/L2TP.
Green Technology
Technology Support D-Link Green Wi-Fi and D-Link Green Ethernet to optimize energy consumption and reduce energy costs.Using Schedule D-Link Green WLAN provides extra protection and reduces power consumption by turning off the wireless network to the user's schedule at peak hours. Technology D-Link Green Ethernet allows to determine the status of the connection and automatically switch the unit to standby power. In addition, routers DSR meet the requirements of the RoHS (Restriction of Hazardous Substances) and WEEE (Waste Electrical and Electronic Equipment), which aim to protect the environment.
Genel Özellikler
Fiziksel Özellikler
Hardware Version
A1
Ethernet Interface
• 1 WAN-port 10/100/1000 Mbit / s
• 8 LAN-port 10/100/1000 Mbit / s
The USB port
1 USB 2.0 port
The console port
RJ-45
Performance 8
• Firewall Throughput 7 : 750 Mbit / s
• VPN throughput 9 95 MBit / s
• The number of concurrent sessions: 20000
• The number of new sessions (per second): 200
• Firewall Policy: 200
Types of Internet connection
• Static / Dynamic IP-address
• PPPoE / L2TP / PPTP
• Multiple PPPoE
Firewall
• A static route
• Dynamic DNS
• Inter-VLAN Routing
• NAT, PAT
• Filtering web-content: Static URL-address keywords
• Intrusion Prevention System (IPS): Signature package included with the software
Network
• Server / Client DHCP
• DHCP Relay
• IEEE802.1q VLAN
• VLAN (port-based)
• IP Multicast: IGMP Proxy
• IPv6 11
• VPN-tunnels: 65
• IPSec-tunnels: 25
• Customers PPTP/L2TP: 25
• GRE 1 : 10
• IPSec NAT Traversal
• Detection of non-performing units
• IP Encapsulating Security
• Payload (ESP)
• IP Authentication Header (AH)
• VPN Tunnel Keep Alive
• Hub and Spoke
Bandwidth Management
• Control the maximum bandwidth
• Management of priority bandwidth:
  - QoS based on port
  - 3 Classes
System control
• Web-user interface: HTTP, HTTPS
• Command Line
• SNMP v1, v2c, v3
Fiziksel Özellikler
Supply
External power supply 12 V DC / 1.5 A
Max. power consumption
11.8 W / 12.6 W
Measurements
140 x 203 x 35 mm
Operating temperature
From 0 to 40 ° C
Storage temperature
-20 To 70 ° C
Operating Humidity
From 5% to 95% non-condensing
EMI / EMC
FCC Class B, CE Class B, C-Tick, IC
Safety
cUL, LVD (EN60950-1)
3rd Party Certification
IPv6 Ready, Wi-Fi, a certificate ICSA, VPNC Basic Interop
MTBF
250,000 hours
3 Only for DSR-500/500N/1000/1000N.
4 The following models of 3G USB-modem: DWM-152 A1/A2/A3, DWM-156 A1/A2/A3/A5 * / A6 *, DWM-157 *, Huawei E1550, E173 and EC306. * USB-modems, marked by an "asterisk" will be supported by further updating the software.
5 Only for DSR-1000N.
6 The list of supported printers is available at URL: http://www.openprinting.org/printers.
7 VPN bandwidth testing was performed using UDP-traffic packet size 1518 bytes, in accordance with RFC2544.
8 The actual performance depends on network conditions and activated services.
9 Test VPN bandwidth performed using UDP-traffic packet size 1420 bytes.
10 Available for future software update.
11 IPv6 Ready Logo (Core) is available for DSR-500/500N and DSR-1000/1000N.
Çözümler
Sipariş Bilgisi
Görseller
DSR-250
Front view
Back view
İndir
Destek Merkezi
