DIR-826L
Dual-band wireless gigabit router Cloud with data transfer rates up to 600 Mbit / s
Nereden Alınır
Tanımlama
Dual-band wireless gigabit router Cloud with data transfer rates up to 600 Mbit / s with attractive design and high performance. In addition, DIR-826L supports service mydlink, which provides remote access to the router from your mobile device.
Dual Band for fast and reliable connection
Dual Band Gigabit Router delivers Cloud computers and mobile devices to broadband Internet access. DIR-826L supports the 802.11n standard with data rates up to 300 Mbit / s 1 , which is ideal for fast file transfer and stable operation of online games. Built-in power amplifier increases wireless coverage, providing a connection anywhere in your home. Simultaneous dual-band allows you to check email and browse the Internet using the 2.4GHz frequency, while the frequency of 5 GHz band can be used to view streaming media. Thus, the user himself determines the most efficient range, depending on the activities performed by it on the network.
Mydlink service
The router supports service mydlink, which provides the ability to remotely access, view and control devices through mydlink web-site or via a mobile app mydlink. The service mydlink you can view information about the users who are connected to the router, change the settings to block unauthorized users from any computer or mobile platforms iOS and Android, connected to the Internet. In addition, parents are available to view and control sites visited by their children.
Quality of Service (QoS)
4 Gigabit LAN-ports on the back panel of the router DIR-826L provide high-speed data transmission over a wired network, ideal for streaming HD-video, stable performance VoIP-applications and online games. Gigabit WAN-port is transmitting data to the wireless interface at high speed, allowing you to maximize the performance of devices in a wireless network.Support for QoS provides analysis and sharing of wired and wireless traffic into multiple data streams, with applications such as VoIP, video streaming and online gaming are given priority.
Sharing and file transfer
Dual Band Wireless Router Cloud allows you to create a data store for shared computers and devices connected to the network. Connect an external USB hard drive to transfer video library and music files on a laptop, or a USB flash drive for presentation shared for your colleagues. Easy-to-use application SharePort ™ Mobile lets you back up photos and videos stored on your device. You can also create separate user accounts to control access to files USB-drive, so access to your music files will be open to everyone, but it will be saved privacy of personal files.
Easy to install and configure security
By the application of QRS (Quick Router Setup) Mobile, installed on a mobile device with an iOS or Android, you can quickly and easily perform start-up and remote management of the router DIR-826L. Just plug in the router, open the application and follow a few simple steps to connect without using a computer. In addition, the protection of the network can be configured one-touch WPS. WPA/WPA2 encryption and a built-in firewall (SPI and NAT) provide network security by allowing you to shop at online stores and perform banking transactions online.
Modern and stylish design
Router DIR-826L made in the original compact body and is a perfect stylistic solution for the modern home. All ports and connectors on the rear panel of the unit, so the router will fit perfectly into any interior and will be a perfect complement it.
Genel Özellikler
Fiziksel Özellikler
Device Interfaces
• 802.11 n / g / b
• 4 Gigabit LAN-port
• Gigabit WAN-port
• USB-2.0 port
Antenna
Internal Antenna
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.11a
• IEEE 802.3
• IEEE 802.3u
The output power of the transmitter
• IEEE 802.11a (5G)
  CH36 ~ CH64
  + 14dBm at 6 ~ 54 Mbit / s for US
  + 20dBm at 6 ~ 54 Mbit / s for the EU
  + 20dBm at 6 ~ 54 Mbit / s for AU
  CH100 ~ CH165
  + 24dBm at 6 ~ 54 Mbit / s for US
  + 24dBm at 6 ~ 54 Mbit / s for the EU
  + 24dBm at 6 ~ 54 Mbit / s for AU
• IEEE 802.11b
  20dBm at 1,2,5.5,11 Mbit / s for US
  17dBm at 1,2,5.5,11 Mbit / s for the EU
  24dBm at 1,2,5.5,11 Mbit / s for AU
• IEEE 802.11g:
  6 ~ 18dBm at 54 Mbit / s for US
  6 ~ 17dBm at 54 Mbit / s for the EU
    For AU:
    + 21dBm at 6 ~ 24 Mbit / s
    + 19dBm at 36 ~ 48 Mbit / s
    + 18dBm at 54 Mbit / s
• IEEE 802.11n (2.4GHz):
  MCS0 ~ 17dBm at 15 for US
  MCS0 ~ 14dBm at 15 for EU
    For AU:
    + 20dBm at MCS0 ~ 3/8 ~ 11
    + 19dBm at MCS4 ~ 6/12 ~ 14
    + 18dBm at MCS7/15
• IEEE 802.11n (5G):
   HT20/40, CH36 ~ CH64
    + 11dBm at MCS-0 ~ 15 for US
    + 17dBm at MCS-0 ~ 15 for the EU
    + 17dBm at MCS-0 ~ 15 for AU
Minimum System Requirements
• Windows 7/Vista/XP SP3 or Mac OS X 10.4 or higher
• Microsoft Internet Explorer 6 or higher, Firefox 1.5 or later, or other Java-enabled browser
• The AC adapter (NIC)
• Cable or DSL-modem
• Subscribe to a service provider
Safety
• WPA and WPA2 (Wi-Fi Protected Access)
• Wi-Fi Protected Setup (WPS) - PIN / PBC
Advanced Features
• The Guest Zone
• Web-access to files
• Web-Wizard in several languages
• Green Ethernet Technology
• Supports UPnP
• The firewall
• Modes VPN passthrough / multi-session PPTP/L2TP/IPSec
Functions mydlink
• Remote control
• View the current bandwidth information outgoing / incoming connections
• Show clients connected at the moment
• View browsing history for each customer
• Lock / Unlock Network Access
• Managing a wireless network
• Access through a Web-browser or mobile app for iOS or Android
Functions SharePort Mobile
• Web-interface to access, download and play files stored on the USB-device
• Setting up a shared storage access by creating multiple accounts
• Share music with preservation of privacy of your files
• SharePort Mobile app for iOS and Android
• Play videos, music and view photos
• Document Viewer
• Backup Media of preservation on the device
Support for mobile applications
• QRS Mobile
• SharePort Mobile
• mydlink Lite
Fiziksel Özellikler
Measurements
93 x 111 x 145 mm
Weight
330 g
Temperature
From 0 to 40 ° C
Humidity
From 10% to 90% (non-condensing)
Certifications
• FCC Class B
• CE Class B
• C-Tick
• Wi-Fi
• Wi-Fi Multimedia (WMM)
• IPv6 Ready
• Compatible with Windows 7
1 The maximum data rate over the air to determine the technical requirements of the standard IEEE 802.11n, 802.11g, 802.11b and 802.11a. Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead transmission can reduce throughput.Environmental factors also adversely affect the strength of the wireless signal. Wireless network range and data rate are relative indicators of D-Link, based on the technical characteristics of these parameters for the product D-Link supports 802.11g wireless standard maximum capacity is based on the performance of equipment D-Link with support for 802.11n.
Çözümler
Sipariş Bilgisi
Görseller
DIR-826L
Front view
Back view
İndir
Destek Merkezi
