DIR-822EOL EOS
Wireless dual band router АС1200
Tanımlama
Wireless interface
Using wireless router DIR-822, You can quickly arrange high-speed wireless network in the home or office, providing access to the Internet, computers and mobile devices almost anywhere (within range of a wireless network). Simultaneous operation in the 2.4 GHz and 5 GHz allows you to use a wireless network to a wide range of tasks. The router can operate as a base station for connecting wireless devices of the standards 802.11 a, 802.11 b, 802.11 g, 802.11 n and 802.11 ac with speeds up to 1167 Mbit/S1 ).
A secure, wireless connection
The router supports multiple functions for the wireless interface. The device supports several security standards (WEP, WPA/WPA2), filtering devices by MAC address, and allows you to use WPS and WMM.
In addition, the device is equipped with a button to disable/enable the Wi-Fi network. If necessary, for example, leaving the house, You can turn off the router's wireless network just one press of the button, while the devices connected to LAN ports of the router will remain in the network.
Advanced wireless network
The ability to customize guest Wi-Fi network will allow You to create a separate wireless network, network security and maximum speed limit. Devices guest network will be able to connect to the Internet, but be isolated from the devices and resources of a local network of the router.
Smart distribution of Wi-Fi clients would be useful for networks consisting of multiple access points or routers D-Link – setting function on each of them You will ensure the client connects to the access point (router) with a maximum signal level.
4-port switch
Built-in 4-port switch allows you to connect computers equipped with Ethernet-adapters, game consoles and other devices to Your network.
Security
The wireless router DIR-822 is equipped with a built-in firewall. The advanced security functions minimize threats of hackers and prevent intrusions to Your network and access to unwanted websites for users Your local network.
Built-in Yandex.DNS provides protection against malicious and fraudulent websites, and also allows you to limit children's access to adult materials.
Easy setup and update
To configure your wireless router DIR-822 userfriendly web-interface (available in several languages).
You can easily upgrade the firmware – the router itself finds approved firmware version on the update server D-Link, and notifies the user that it is ready to install.
1 up To 300 Mbps in the 2.4 GHz band and up to 867 Mbps in the 5 GHz band.
