DIR-822EOL EOS
Wireless dual band router АС1200
Nereden Alınır
Tanımlama
Wireless interface Using wireless router DIR-822, You can quickly arrange high-speed wireless network in the home or office, providing access to the Internet, computers and mobile devices almost anywhere (within range of a wireless network). Simultaneous operation in the 2.4 GHz and 5 GHz allows you to use a wireless network to a wide range of tasks. The router can operate as a base station for connecting wireless devices of the standards 802.11 a, 802.11 b, 802.11 g, 802.11 n and 802.11 ac with speeds up to 1167 Mbit/S1 ). A secure, wireless connection The router supports multiple functions for the wireless interface. The device supports several security standards (WEP, WPA/WPA2), filtering devices by MAC address, and allows you to use WPS and WMM. In addition, the device is equipped with a button to disable/enable the Wi-Fi network. If necessary, for example, leaving the house, You can turn off the router's wireless network just one press of the button, while the devices connected to LAN ports of the router will remain in the network. Advanced wireless network The ability to customize guest Wi-Fi network will allow You to create a separate wireless network, network security and maximum speed limit. Devices guest network will be able to connect to the Internet, but be isolated from the devices and resources of a local network of the router. Smart distribution of Wi-Fi clients would be useful for networks consisting of multiple access points or routers D-Link – setting function on each of them You will ensure the client connects to the access point (router) with a maximum signal level. 4-port switch Built-in 4-port switch allows you to connect computers equipped with Ethernet-adapters, game consoles and other devices to Your network. Security The wireless router DIR-822 is equipped with a built-in firewall. The advanced security functions minimize threats of hackers and prevent intrusions to Your network and access to unwanted websites for users Your local network. Built-in Yandex.DNS provides protection against malicious and fraudulent websites, and also allows you to limit children's access to adult materials. Easy setup and update To configure your wireless router DIR-822 userfriendly web-interface (available in several languages). You can easily upgrade the firmware – the router itself finds approved firmware version on the update server D-Link, and notifies the user that it is ready to install. 1 up To 300 Mbps in the 2.4 GHz band and up to 867 Mbps in the 5 GHz band.
Genel Özellikler
Fiziksel Özellikler
Hardware Interfaces • WAN port 10/100BASE-TX • 4 LAN port 10/100BASE-TX Indicators • Power • Internet • WPS • Wireless network • 4 indicator LAN Button • POWER button to turn on/off power switch • RESET button for system reset • WPS button to establish the secure wireless connection and enable/disable the wireless network Antenna • Four external non-removable antenna with a gain of 5 dBi Scheme MIMO • 2 x 2 Power connector • Connect power supply (DC) Software Connection types WAN • PPPoE • IPv6 PPPoE • PPPoE Dual Stack • Static IP / Dynamic IP • Static IPv6 / Dynamic IPv6 • PPPoE + Static IP / Dynamic IP • PPTP/L2TP + Static IP • PPTP/L2TP + Dynamic IP Network functions • Support IEEE 802.1 X to connect to the Internet • DHCP server/relay • DHCPv6 server (Stateful/Stateless), IPv6 prefix delegation • DNS relay • Record support of DNSv6 AAAA class • Dynamic DNS • Static IP routing • Static IPv6 routing • IGMP Proxy • RIP • Support UPnP IGD • VLAN support • Supports ping from the external network (WAN ping respond) • Supports SIP ALG • Support RTSP • Configure the speed, duplex mode and function flow control (flow control) mode auto-negotiation/Manual setting of speed and duplex mode for each Ethernet port The firewall features • Network address translation (NAT) • Monitoring the status of network connections (SPI) • IP filter • IPv6-filter • MAC filter • URL filter • DMZ-zone • The protection ARP - and DDoS-attacks • Virtual servers • Built-in content filtering service Yandex.DNS VPN • IPSec/PPTP/L2TP/PPPoE pass-through • IPSec tunnels Management • Local and remote access settings for TELNET/WEB (HTTP/HTTPS) • Web interface configuration and management in multiple languages • Notification on connection problems and auto redirect to settings • Update the firmware of the router through the web interface • Automatic notification about new version • Save and load configuration • Support for remote logging • Automatic synchronization of system time with NTP server and manual setting of date and time • The ping utility • Traceroute utility • Client TR-069 The parameters of the wireless module Standards • IEEE 802.11 a/n/ac • IEEE 802.11 b/g/n Frequency range • 2400 ~ MHz-2483.5 MHz • 5150 ~ 5350 MHz Wireless security • WEP • WPA/WPA2 (Personal/Enterprise) • MAC-filter • WPS (PBC/PIN) Additional features • A "client" • WMM (Wi-Fi QoS) • Information about a connected Wi-Fi clients • Advanced settings • Intelligent allocation of Wi-Fi clients • Guest Wi-Fi network for each band • Limit speed wireless network The speed of the wireless connection • IEEE 802.11 a: 6, 9, 12, 18, 24, 36, 48 and 54 Mbps • IEEE 802.11 b: 1, 2, 5.5 and 11 Mbps • IEEE 802.11 g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbps • IEEE 802.11 n (2.4 GHz/5GHz): from 6.5 to 300Mbps (from MCS0 to MCS15) • IEEE 802.11 ac (5 GHz): 6.5 to 867 Mbit/s (MCS0 to MSC9) Transmitter output power The maximum value of the transmitter power will vary in accordance with the rules of the radio-frequency regulation in Your country • 802.11 a (typical at room temperature 25 °C) 15 dBm (+/-2 dB) at 6, 9, 12, 18, 24, 36 Mbit/s 14 dBm (+/-2 dB) at 48 Mbps 13 dBm (+/-2 dB) at 54Mbps • 802.11 b (typical at room temperature 25 °C) 15 dBm (+/-2 dB) at 1, 2, 5,5, 11 Mbit/s • 802.11 g (typical at room temperature 25 °C) 15 dBm (+/-2 dB) at 6, 9, 12, 18, 24, 36, 48 , 54 Mbps • 802.11 n (typical at room temperature 25 °C) 2.4 GHz HT20 15 dBm (+/-2 dB) at MCS0~5 14 dBm (+/-2 dB) at MCS6~7 2.4 GHz, HT40 15 dBm (+/-2 dB) at MCS0~5 14 dBm (+/-2 dB) at MCS6~7 5 GHz HT20/HT40 17 dBm at MCS0~5 14 dBm at MCS6 13 dBm at MCS7 • 802.11 ac (typical at room temperature 25 °C) VHT20 15 dBm @ MCS0~5 14 dBm at MCS6 13 dBm at MCS7 12 dBm at MCS8 VHT40 15 dBm @ MCS0~5 14 dBm at MCS6 13 dBm at MCS7 12 dBm at MCS8 11 dBm @ MCS9 VHT80 13 dBm at MCS0~7 12 dBm at MCS8 11 dBm @ MCS9 The receiver sensitivity • 802.11 a (typical at PER < 10% packet size 1000 bytes at room temperature 25 °C) -82 dBm at 6 Mbit/c -81 dBm at 9 Mbit/c -79 dBm at 12 Mbps/c -77 dBm at 18 Mbps -74 dBm at 24 Mbps -70 dBm at 36 Mbps/c -66 dBm at 48 Mbps/c • -65 dBm @ 54Mbps • 802.11 b (typical at PER = 8% at room temperature 25 °C) -84 dBm @ 1, 2 Mbps -82 dBm at 5.5 Mbit/s -79 dBm at 11 Mbit/s • 802.11 g (typical at PER = 10% at room temperature 25 °C) -82 dBm at 6 Mbit/c -81 dBm at 9 Mbit/c -79 dBm at 12 Mbps/c -77 dBm at 18 Mbps -74 dBm at 24 Mbps -70 dBm at 36 Mbps/c -66 dBm at 48 Mbps/c • -65 dBm @ 54Mbps • 802.11 n (typical at PER = 10% at room temperature 25 °C) HT20 -82 dBm at MCS0 -79 dBm at MCS1 -77 dBm at MCS2 -74 dBm @ MCS3 -70 dBm at MCS4 -66 dBm at MCS5 -65 dBm at MCS6 -64 dBm at MCS7 HT40 -79 dBm at MCS0 -76 dBm at MCS1 -74 dBm at MCS2 -71 dBm @ MCS3 -67 dBm at MCS4 -63 dBm at MCS5 -62 dBm at MCS6 • -61 dBm at MCS7 • 802.11 ac (typical at PER = 10% at room temperature 25 °C) HT20 -82 dBm at MCS0 -79 dBm at MCS1 -77 dBm at MCS2 -74 dBm @ MCS3 -70 dBm at MCS4 -66 dBm at MCS5 -65 dBm at MCS6 -64 dBm at MCS7 -59 dBm at MCS8 -57 dBm @ MCS9 HT40 -79 dBm at MCS0 -76 dBm at MCS1 -74 dBm at MCS2 -71 dBm @ MCS3 -67 dBm at MCS4 -63 dBm at MCS5 -62 dBm at MCS6 -61 dBm at MCS7 -56 dBm at MCS8 -54 dBm @ MCS9 HT80 -76 dBm @ MCS0 -73 dBm at MCS1 -71 dBm at MCS2 -68 dBm at MCS3 -64 dBm at MCS4 -60 dBm at MCS5 -59 dBm at MCS6 -58 dBm at MCS7 -53 dBm at MCS8 -51 dBm @ MCS9 Modulation schemes • 802.11 a: BPSK, QPSK, 16QAM, 64QAM with OFDM • 802.11 b: DQPSK, DBPSK, DSSS, CCK • 802.11 g: BPSK, QPSK, 16QAM, 64QAM with OFDM • 802.11 n: BPSK, QPSK, 16QAM, 64QAM with OFDM • 802.11 ac: BPSK, QPSK, 16QAM, 64QAM, 256QAM with OFDM Physical parameters Dimensions (l x W x h) • 190 x 133 x 38 mm Weight • 263 g Operating conditions Food • Output: 12V DC, 0.5 A Temperature • Operating: 0 to 40 °C • Storage: -20 to 65 °C Humidity • Operating: 10% to 90% (no condensation) • Storage: 5% to 95% (non-condensing) The package • The DIR-822 • Power adapter DC 12V/0.5 A • Ethernet cable • The document "Quick installation guide" (booklet)
Çözümler
Sipariş Bilgisi
Görseller
DIR-822
Back view
View from the right
Front view
İndir
Destek Merkezi
