DIR-330EOL EOS
Tanımlama
D-Link answers the need for a Wireless G VPN Router with the DIR-330. The DIR-330 is an easy-to-deploy wireless routing, 10/100 switching, VPN, and frewall solution designed specifcally for the Small Offce / Home Offce (SOHO) market that demands superior performance and security.
User Confgurable Interface
The DIR-330 features an intuitive user interface that can easily be confgured and monitored via D-Link’s Web-based management utility. These confguration options can be managed through the default Admin account or you may replace the “admin” username with name you desire for better security.
Advanced Hardware Features
The DIR-330 can be connected to a cable or DSL modem to share high-speed Internet access. It also doubles as a 4-port full-duplex 10/100 switch to connect up to four Ethernet-enabled devices. Simply add more switches to expand your wired network. This router also functions as a wireless 802.11g/802.11b access point to connect wireless devices onto your network. In addition, you can create a Virtual Private Network (VPN) with the DIR-330 and allow up to eight off-site or traveling users to securely access your central network through the Internet at the same time.
VPN Performance
For optimal VPN confguration, the DIR-330 has an integrated VPN Client and Server to support almost any required VPN policy. This device has a hardware VPN engine to support and manage up to 25 VPN confgurations. The DIR-330 can support IPSec, PPTP, and L2TP protocols in Server mode and can handle pass-through traffc as well. Advanced VPN confguration options include: DES/3DES/AES/Twofsh/Blowfsh encryption, IKE/ISAKMP key management, Quick/Main/Aggressive Negotiation modes, and VPN authentication support using the internal 150-user database.
Enterprise-class Security
The DIR-330 can encrypt all wireless transmission using WPA™ or WPA2™ to protect your network. It also protects your network from online intruders and potential attacks with Dual Active Firewall protection using Network Address Translation (NAT) and Stateful Packet Inspection (SPI).
With small businesses becoming increasingly network-dependent, the need to invest in a reliable security solution is crucial. The D-Link Wireless G VPN Router (DIR-330) offers high return on investment through robust security features, fexible confguration, and superb network protection for small offces and home networks
Genel Özellikler
Standards
+ IEEE 802.3
+ IEEE 802.3u
+ IEEE 802.11g
+ IEEE 802.11b
Ports
+ 4 10/100 LAN
+ 1 10/100 WAN
+ 1 USB 2.0
Firewall Mode of operation
+ Layer 3 Mode: Route Mode, NAT Mode
+ Network Address Translation (NAT)
+ Port Forwarding
+ Port Address translation (PAT)
VPN Security
+ VPN Tunnels: 8 (IPSec, PPTP, L2TP)
+ IPSec LAN-to-LAN / Remote User
+ PPTP/L2TP Server/Client
+ IPSec/PPTP/L2TP Pass-through
+ IPSec NAT-Traversal
+ DHCP over IPSec
+ Encryption transform: DES, 3DES, AES
+ XAUTH (Extended Authentication) for iPSec Authentication
Firewall Security
+ Stateful Packet Inspection (SPI)
+ Internal User Database (20 Records)
Network Service
+ Static iP Address
+ PPPoE for XDSL
+ DHCP Client for WAN Interface
+ Internal DHCP Server
+ Static Routes
+ DNS Resolving of Remote Gateway
+ DHCP over IPSec
+ Dynamic DNS
+ Russian PPPoE/PPTP (dual Access)
Device Management
Internet Explorer or later, or other Java-enabled Browsers
LEDs
+ Power
+ Status
+ LAN
+ WAN
+ WLAN
+ USB
Çözümler
Sipariş Bilgisi
DIR-330 Wireless VPN Router with IPSec and 4-port Switch
